Home » Eclipse Projects » Eclipse Platform » How to replace text in editor
How to replace text in editor [message #329501] Thu, 26 June 2008 05:16 Go to next message
Originally posted by: chingyichan.tw.gmail.com
I am learning to write a plugin. My target is replacing the selected text.
The selection I know how to do, but how to replace the selection as any
string ?
I try use the
window.getActivePage().getActiveEditor().getEditorInput()
to get FileEditorInput and get the IFile instance.
it can append contents or set contents in the file,
but I only want to modfiy the editor buffer not the real file.
Any suggestion?
Re: How to replace text in editor [message #329606 is a reply to message #329501] Sun, 29 June 2008 21:31 Go to previous message
Ching Yi, Chan 提到:
> string ?
> I try use the
> to get FileEditorInput and get the IFile instance. it can append
> contents or set contents in the file, but I only want to modfiy the
> Any suggestion?
I found that I can use IDocument to modify my text buffer.
REF :
http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.platfo rm/msg43276.html
Previous Topic:java.lang.UnsupportedClassVersionError: Bad version number in .class file
Next Topic:command-line update (update manager)
Current Time: Sat Jul 26 14:09:50 EDT 2025
Powered by FUDForum. Page generated in 1.07836 seconds
