Home » Archived » BIRT » Report Parameter Combo Items
Report Parameter Combo Items [message #33364] Tue, 03 May 2005 09:12 Go to next message
Originally posted by: Zohair.hasan.snstech.com
While getting the parameter input from user,if its a Combo Box,can we
retrive the items from Database.Say i want to get the details of the
specefic department supplied by the user as input,can Combo list be
dynamically generated? for example from database,so that modifications in
database will reflect the Combo items of Report Parameters too.
Is there any possibility by which we can implement this in Birt.
Anyone got this working, please help!!
Using Birt M2 build .
Thanks in advance
Re: Report Parameter Combo Items [message #33469 is a reply to message #33364] Tue, 03 May 2005 10:33 Go to previous messageGo to next message
Originally posted by: a14342.gmail.com
Zohair,
Just my looking at the screen, options,it doesnt look it is possible to
get the data from database to populate the list box..I also had a exact
question!!.
On a side note, do you know how to bind a report parameter and data set
parameter ?
-Naveen
Zohair wrote:
> Thanks in advance
Re: Report Parameter Combo Items [message #33711 is a reply to message #33469] Tue, 03 May 2005 17:09 Go to previous messageGo to next message
Naveen & Zohair,
BIRT 1.0 won't provide dynamic parameters (lists that come from the
database), but it is proposed for a later release. The proposed design is
described in the ROM specs in the section that describes parameters.
Briefly, the idea is that you'll be able to declare a BIRT data set that
provides the data, and that data set will be used to obtain the list. Does
this feature sound like one that would solve your problem? Are there
specific requirements you can suggest?
In the mean time, you can create a custom parameter page using JSP or PHP.
You can use the Java or PHP techniques for accessing the database. The
custom parameter pages allow you to integrate these pages more closely with
your application, then delegate to BIRT the responsibility of running the
reports. Will this solution work for your app, or would you prefer to use
the BIRT parameter UI?
There was question about how to bind a report and data set parameter. See
this page for details:
http://www.eclipse.org/birt/index.php?page=faq/params.html
And, see the Data Set Parameters section of this page:
http://www.eclipse.org/birt/index.php?page=faq/data.html
- Paul
Paul Rogers
BIRT PMC
"Naveen" <a14342@gmail.com> wrote in message
news:f398b643d2202366a7426ffd66d89800$1@www.eclipse.org...
> Zohair,
> question!!.
> parameter ?
> -Naveen
> Zohair wrote:
>> Thanks in advance
BIRT Documentation [message #33975 is a reply to message #33711] Wed, 04 May 2005 00:24 Go to previous messageGo to next message
Hi Paul,
Just want to know what we will expect on documentaion or help file that
comes with BIRT 1.0 that will be released this coming May 15...does it
contains topic such as on how to use parameter, sub-report, integration,
scripting and etc..
thanks,
wins
Re: Report Parameter Combo Items [message #34237 is a reply to message #33711] Wed, 04 May 2005 14:24 Go to previous messageGo to next message
Originally posted by: Zohair.Hasan.snstech.com
Thanks paul for your reply.As you suggested,creating a JSP page will
resolve my issue of generating the Input Parameters dynamically(from
database),the problem i am facing currently is invoking the Birt
Application from my Struts based applications and deligating the
parameters passed by JSP to the Birt report.
Can anybody help me out in this??
Thanks in Advance.
-Zohair
Re: Report Parameter Combo Items [message #34306 is a reply to message #34237] Wed, 04 May 2005 18:22 Go to previous messageGo to next message
Zohair,
A quick solution is to redirect the web browser to the BIRT web app. See the
"PHP" page on the "integration" area of the BIRT web page for an example,
and the the Viewer areas on the "integration" area for the format of the URL
to run & display a report.
Longer term, you can use the components within the BIRT web app (viewer) as
examples of how to call the report engine directly.
- Paul
Paul Rogers
BIRT PMC
"Zohair" <Zohair.Hasan@snstech.com> wrote in message
news:1c68b43f5058eb210bfc6a59fb9d10d6$1@www.eclipse.org...
> Thanks in Advance.
> -Zohair
Re: BIRT Documentation [message #34340 is a reply to message #33975] Wed, 04 May 2005 18:27 Go to previous messageGo to next message
Wins,
The goal is to provide comprehensive online help in the 1.0 release in May.
Some topics may not quite be ready, but will appear in subsequent releases.
A BIRT book will also be available this year.
- Paul
Paul Rogers
BIRT PMC
"wins" <winstonguadiz@yahoo.com> wrote in message
news:e13dec98ac983f2383bb8e3ba3124716$1@www.eclipse.org...
> Hi Paul,
> scripting and etc..
> thanks,
> wins
Re: BIRT Documentation [message #34375 is a reply to message #34340] Wed, 04 May 2005 18:33 Go to previous messageGo to next message
Parameters and sub-reports will certainly be covered in the first release of
the documentation. There will be some information about integration. I can't
say for sure what will be available on the subject of scripting.
Jane Tatchell
BIRT documentation lead
"Paul Rogers" <progers@actuate.com> wrote in message
news:d5bijt$gd5$1@news.eclipse.org...
> Wins,
May.
releases.
> - Paul
> Paul Rogers
> BIRT PMC
> > Hi Paul,
> > scripting and etc..
> > thanks,
> > wins
Re: BIRT Documentation [message #34511 is a reply to message #34375] Wed, 04 May 2005 23:26 Go to previous messageGo to next message
thanks for the info...
wins
Re: Report Parameter Combo Items [message #34545 is a reply to message #33711] Thu, 05 May 2005 01:34 Go to previous messageGo to next message
Paul,
I tried binding the Dataset and report parameter. After binding, data is
not getting retrieved from database dynamically based on what user
entered. Data retreived from datbase is based on the defaul value entered
in the Data set parameter only.
I also tried not giving any value in Data set parameter default. Still
data is not getting retreived from database based on user input.
I am using Tomcat 4.1.3 and M2 build.
-Naveen
Paul Rogers wrote:
> Naveen & Zohair,
> - Paul
> Paul Rogers
> BIRT PMC
>> Zohair,
>> question!!.
>> parameter ?
>> -Naveen
>> Zohair wrote:
>>> Hi,
>>> Thanks in advance
Re: Report Parameter Combo Items [message #36036 is a reply to message #34545] Tue, 10 May 2005 17:18 Go to previous message
Naveen,
Sorry for the delay in responding. The parameter value passing should work
in M2 and M3. Here are some things to try:
1. Create a data item at the top of your report to display the report
parameter value. Does it look right?
2. Double-check that the data set parameter is bound to the report parameter
in the the Binding page of the property editor for your Table or List report
item.
3. When you test your data set in the Data Set editor, does it display only
those rows that match the default value of your data set parameter? If not,
then double-check that your query has a WHERE something = ? clause.
If all else fails, please e-mail me your design file and I'll see if I can
figure out what might be wrong.
- Paul
Paul Rogers
BIRT PMC
news:f7472ca2c17357cb45e7b2d2e30d6599$1@www.eclipse.org...
> Paul,
> -Naveen
> Paul Rogers wrote:
>> Naveen & Zohair,
>> Does this feature sound like one that would solve your problem? Are there
>> PHP. You can use the Java or PHP techniques for accessing the database.
>> The custom parameter pages allow you to integrate these pages more
>> closely with your application, then delegate to BIRT the responsibility
>> of running the reports. Will this solution work for your app, or would
>> you prefer to use the BIRT parameter UI?
>> Thanks,
>> - Paul
>> Paul Rogers
>> BIRT PMC
>>> Zohair,
>>> question!!.
>>> parameter ?
>>> -Naveen
>>> Zohair wrote:
>>>> Hi,
>>>> in database will reflect the Combo items of Report Parameters too.
>>>> Thanks in advance
Previous Topic:Oda data source and the 'Edit Data set' dialog, query getting lost
Next Topic:Engine API & M3 install info posted
Current Time: Sat Jun 21 08:52:11 EDT 2025
Powered by FUDForum. Page generated in 0.06250 seconds
