Home » Eclipse Projects » Eclipse Platform » Unhandled event loop exception
Unhandled event loop exception [message #329456] Wed, 25 June 2008 02:49 Go to next message
Originally posted by: maxipower_q.yahoo.com
i'm designing a plugin. yesterday i changed somethings(!) in the code and
eclipse started giving me this exception.
i tried to take the changes back but i couldn't figure it.
as you can see in the log file, createImageIcon must the problem.
could someone tell me how to solve the problem ?
Thanks...
createImageIcon function*******************************
protected ImageIcon createImageIcon(String path,String description) {
java.net.URL imgURL = getClass().getResource(path);
if (imgURL != null) {
return new ImageIcon(imgURL, description);
else {
textarea.setText("Couldn't find file: " + path);
return null;
code where i call the function*************************
ImageIcon icon = createImageIcon("/icons/Banner.gif","Banner");
label3 = new JLabel(icon);
label3.setBackground(Color.WHITE);
bannerPanel.setBackground(Color.WHITE);
bannerPanel.add(label3);
ERROR.LOG**********************************************
at argela.plugins.rename13.actions.Rename.createImageIcon(Renam e.java:572)
at argela.plugins.rename13.actions.Rename.<init>(Rename.java:105)
argela.plugins.rename13.actions.Application.getInstance(Appl ication.java:24)
at argela.plugins.rename13.actions.Application.run(Application. java:18)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:256)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Re: Unhandled event loop exception [message #329457 is a reply to message #329456] Wed, 25 June 2008 03:24 Go to previous messageGo to next message
Originally posted by: fraserofthenight.gmail.com
> and eclipse started giving me this exception.
> Thanks...
> else {
> return null;
> ImageIcon icon = createImageIcon("/icons/Banner.gif","Banner"); label3 =
> new JLabel(icon);
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Are you sure textarea is not null?
Re: Unhandled event loop exception [message #329458 is a reply to message #329457] Wed, 25 June 2008 04:07 Go to previous message
no (: thanks ,it solved my problem.
program was trying to write an error to nowhere..
i took the icon creation code after the textarea's initializiation.
Thanks again.
Previous Topic:Vista Bug using Nebula CDatetime
Next Topic:Delete a project from project explorer
Current Time: Sat Jul 26 00:18:05 EDT 2025
Powered by FUDForum. Page generated in 0.14812 seconds
