Prevent Eclipse from passing -Dfile.encoding to projects [message #1732407] |
Mon, 16 May 2016 23:43 |
Ashton Holmes Messages: 2 Registered: September 2015 |
Eclipse is passing -Dfile.encoding to the JVM whenever I launch my projects and it's been causing my JavaFX applications(all of them) to crash. The issue is a SIGSEGV going to libfreetype.so.6. Given that it happens with all JavaFX applications I'm pretty sure it's a bug with JavaFX or libfreetype6 and so there's nothing I can do. This even happens from the command line. However, launching the applications from the command line without that parameter works just fine and I have no issues. I would like to stop eclipse from passing -Dfile.encoding to the JVM. I've checked the default JVM args as well as the individual run configuration args but no where is that argument being specified. I know for a fact eclipse is specifying it because the crash logs list it as a parameter going to the JVM at launch. Is there any way for me to prevent eclipse from passing this to the JVM?
[Updated on: Mon, 16 May 2016 23:51] Report message to a moderator
FUDForum. Page generated in 0.03448 seconds
