Home » Eclipse Projects » Eclipse Platform » showPerspective send a "invalid access thread"
showPerspective send a "invalid access thread" [message #329391] Sun, 22 June 2008 14:40 Go to next message
hi,
in my code (in a LaunchConfigurationDelegate subclasses) I try to change
the perspective to get the debugperspective so I use this.
PlatformUI.getWorkbench().showPerspective(
IDebugUIConstants.ID_DEBUG_PERSPECTIVE,
PlatformUI.getWorkbench().getActiveWorkbenchWindow()
but I have an invalid access thread And I have no idea why.
there the full code
try {
if (mode.equals(ILaunchManager.DEBUG_MODE)) {
PlatformUI.getWorkbench().getActiveWorkbenchWindow());
command = "cmd.exe /C \"set YINPUT=1
&& set YDEBUG=1 && "
+ command + "\"";
System.out.println(command);
Process process = Runtime.getRuntime().exec(command);
IProcess p = DebugPlugin.newProcess(launch, process, path
.removeLastSegments(1).toOSString());
launch.addProcess(p);
IDebugTarget target = new YaflDebugTarget(launch, p);
launch.addDebugTarget(target);
} catch (IOException e) {
e.printStackTrace();
Re: showPerspective send a "invalid access thread" [message #329399 is a reply to message #329391] Mon, 23 June 2008 04:21 Go to previous messageGo to next message
Hi Julien,
The call that you are making is a UI call. And it should be invoked on the
UI thread I think. You could try doing
PlatformUI.getWorkbench().getDisplay().asyncExec/syncExec(Ru nnable) and
putting your code inside this runnable and then try invoking again.
Rahul
"julien" <elekis@gmail.com> wrote in message
news:g3m6b9$t3i$1@build.eclipse.org...
> hi,
> there the full code
> try {
> + command + "\"";
Re: showPerspective send a "invalid access thread" [message #329409 is a reply to message #329399] Mon, 23 June 2008 09:19 Go to previous messageGo to next message
Rahul Kamdar a écrit :
> Hi Julien,
> Rahul
yeah, thats work thanks a lot
A+++
>> hi,
>> there the full code
>> try {
>> + command + "\"";
Re: showPerspective send a "invalid access thread" [message #329431 is a reply to message #329409] Tue, 24 June 2008 04:13 Go to previous message
julien,
Ideally you shouldn't be doing this at all. Switching to the debug
perspective is done by the workbench automatically. The behaviour is
controlled by the preference: Run/Debug->Perspective->Open the
associated perspective when lauching.
- Prakash
www.eclipse-tips.com
>> Hi Julien,
>> the UI thread I think. You could try doing
>> and putting your code inside this runnable and then try invoking again.
>> Rahul
> A+++
>>> hi,
>>> change the perspective to get the debugperspective so I use this.
>>> there the full code
>>> try {
>>> + command + "\"";
Previous Topic:DnD for multiple TransferTypes
Next Topic:Setting content types on a per-project basis
Current Time: Mon Jul 21 23:56:15 EDT 2025
Powered by FUDForum. Page generated in 0.04953 seconds
