Importing existing Bundles [message #33348] |
Wed, 14 January 2004 19:27  |
What's the best way to import the code for an existing OSGi bundle into
Eclipse so that it can be dynamically included in other plugin/bundles'
dependencies? The bundle already has a BundleActivator. I've tried
creating a new Plugin, importing the source code, then converting the
whole thing to an OSGi bundle. It seems to work, but I'm sure that's the
best approach.
Stephen
Re: Importing existing Bundles [message #33508 is a reply to message #33421] |
Wed, 14 January 2004 20:53   |
Hmm... keeping me guessing, eh? Actually, I haven't figured out how to
start the initial eclipse workspace with the console. I've tried running
"eclipse -console" from cmd (windows xp) but that seems to use javaw, so
there's no console. Either way, I'd really like to import the bundle into
its own project so I can continue to develop it.
Stephen
Jeff McAffer wrote:
> "Jeff McAffer" <jeff_mcaffer_REMOVE@ca.ibm.com> wrote in message
> news:bu4qoi$78c$1@eclipse.org...
> > You should just be able to run it as per normal. The "detail" is how to
> get
> > the darn thing installed. Two real choices
> > 1) install using the console
> > 2) insert a
> > "Stephen Goldbaum" <stephen.goldbaum@lehman.com> wrote in message
> > news:bu4mqc$3ek$1@eclipse.org...
> the
> > > best approach.
> > > Thanks,
> > > Stephen
Re: Importing existing Bundles [message #33712 is a reply to message #33508] |
Thu, 15 January 2004 23:36   |
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
The eclipse.exe has not been updated to know about -console (and to then use
java.exe). Two options:
eclipse.exe -console -consolelog
or
eclipse.exe -console -vm <path to java.exe>
Jeff
news:bu4rr4$879$1@eclipse.org...
> Stephen
to
> > get
> > > 2) insert a
into
plugin/bundles'
the
that's
> > the
> > > > best approach.
> > > > Thanks,
> > > > Stephen
Re: Importing existing Bundles [message #33912 is a reply to message #33712] |
Fri, 16 January 2004 10:31  |
Thanks. That did the trick.
> or
> Jeff
> > Thanks,
> > Stephen
> to
> > > get
> > > > 2) insert a
> into
> plugin/bundles'
> the
> that's
> > > the
> > > > > best approach.
> > > > > Thanks,
> > > > > Stephen
FUDForum. Page generated in 0.09545 seconds
