Home » Eclipse Projects » Eclipse Platform » eclipse startup
eclipse startup [message #329188] Mon, 16 June 2008 11:53 Go to next message
Originally posted by: prasad.chand.gmail.com
Hi All,
I wish to "initialize" certain non-static classes at the beginning of a
plugin startup. I want to access this class using some kind of
mechanism. Presently I am using a workaround by declaring them in a view
and obtaining the instance of the view using
Viewpart view =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().
findViewReference(View.ID).getView(false);
view.getObject();
I looked at the startup extension point but I am not sure if it could
get the job done. Any help would be great.
Thank,
Prasad
Re: eclipse startup [message #329197 is a reply to message #329188] Mon, 16 June 2008 12:26 Go to previous messageGo to next message
Prasad Chand wrote:
> Hi All,
Often you see the plugin activator class (subclass of AbstractPlugin or
AbstractUIPlugin) have references to objects that are used across the
plugin. So in the activator's start() method you initialize them and
then provide access to other classes via getter methods.
Or you could use a factory that provides access to the shared objects
and call its initialization method(s) from the activator's start() method.
Hope this helps,
Eric
Re: eclipse startup [message #329203 is a reply to message #329197] Mon, 16 June 2008 12:38 Go to previous messageGo to next message
Eric Rizzo wrote:
> Prasad Chand wrote:
>> Hi All,
>> a plugin startup. I want to access this class using some kind of
>> view and obtaining the instance of the view using
I have tried this but as i said I am not able to obtain non-static objects.
MyPlugin.<non-static object> is not possible by this method.
Can you please elaborate as to how I can achieve this.I am just not able
to obtain the non-static instance of the object I want.
> Hope this helps,
> Eric
Thanks for your time,
Prasad
Re: eclipse startup [message #329249 is a reply to message #329203] Tue, 17 June 2008 09:20 Go to previous messageGo to next message
Prasad Chand wrote:
> Eric Rizzo wrote:
>> Prasad Chand wrote:
>>> Hi All,
>> or AbstractUIPlugin) have references to objects that are used across
>> the plugin. So in the activator's start() method you initialize them
>> and then provide access to other classes via getter methods.
If you let the Eclipse proejct wizard generate the activator class for
you, you'll notice that it includes a static singleton variable and
accessor method (getDefault()). You can use this to get to the instance
and through that get to any references to other objects that it contains.
Hope this helps,
Eric
Re: eclipse startup [message #329257 is a reply to message #329249] Tue, 17 June 2008 13:11 Go to previous message
Eric Rizzo wrote:
> Prasad Chand wrote:
>> Eric Rizzo wrote:
>>> Prasad Chand wrote:
>>>> Hi All,
>>>> of a plugin startup. I want to access this class using some kind of
>> objects.
Works fine now. Thanks a lot.
Prasad
> Hope this helps,
> Eric
Previous Topic:Add an action to both main menu & view context menu
Next Topic:Migration Questions
Current Time: Fri Jul 18 21:50:20 EDT 2025
Powered by FUDForum. Page generated in 0.13459 seconds
