Home » Eclipse Projects » Eclipse Platform » Run as ... issue
Run as ... issue [message #329148] Fri, 13 June 2008 16:09 Go to next message
The Run as button used to work such that if I just clicked on it, it ran
the most recently run java application. It doesn't do this anymore. Now,
to run the most recent application, I have to pull down and select it.
Can anyone tell me what happened to this functionality?
Win XP
Version: 3.3.2
Build id: M20080221-1800
Re: Run as ... issue [message #329149 is a reply to message #329148] Fri, 13 June 2008 16:23 Go to previous messageGo to next message
In 3.3 a change was introduced so that it now runs the launch
configuration that makes the most sense for the active editor.
Open the "Run/Debug > Launching" page in the preferences. In the "Launch
Operation" section, you can change the behaviour.
HTH,
Wayne
> Win XP
> Version: 3.3.2
Re: Run as ... issue [message #329150 is a reply to message #329148] Fri, 13 June 2008 16:33 Go to previous messageGo to next message
It was intentionally changed in for 3.3. It is described on this "New &
Noteworthy" page:
http://archive.eclipse.org/eclipse/downloads/drops/R-3.3-200 706251500/whatsnew/eclipse-news-part1.html
Look for the section named "Launch selection vs. launch last" near the
bottom.
The good news is, you can revert to the old behavior by toggling a
preferences setting (also described in the above document).
Hope this helps,
Eric
Re: Run as ... issue [message #329151 is a reply to message #329150] Fri, 13 June 2008 17:14 Go to previous message
Eric, Wayne, thank you
Previous Topic:New Common Navigator Framework blog
Next Topic:error "resource is out of sync with the file system"
Current Time: Fri Sep 12 20:53:37 EDT 2025
Powered by FUDForum. Page generated in 0.03964 seconds
