open external editor on a file NOT in the workspace ... [message #329048] |
Wed, 11 June 2008 06:09  |
Hi all,
I need to open an external editor on a file not present in the workspace .
My action already works fine if I specify the default external editor . but
it doesn't if I try to open a specific program . what am I doing wrong?
What shall I do to solve the problem?
Thanks for ur help
Kar
If the editor descriptor is
EditorDescriptor(id=org.eclipse.ui.systemExternalEditor, label=&System
Editor) WORKS FINE ...
EditorDescriptor(id=C:\Program Files\Scintilla Text Editor\SciTE.exe,
label=SciTE) DOESN'T ...
(I got the name from the eclipse dialog that lists all the external
programs.)
IFileStore fileStore = Utils.getFileStore(file);
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
page.openEditor(new FileStoreEditorInput (fileStore),
editorDescriptor.getId());
public static IFileStore getFileStore(java.io.File file)
IFileStore fileStore = EFS.getLocalFileSystem().getStore(
new Path(file.getParentFile().getAbsolutePath()));
return fileStore.getChild(file.getName());
org.eclipse.ui.PartInitException: Unable to open editor, unknown editor ID:
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:629)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2557)
com.xxx.inspector.ui.views.actions.OpenFileOperation.openEdi tor(OpenFileOperation.java:86)
Re: open external editor on a file NOT in the workspace ... [message #329062 is a reply to message #329048] |
Wed, 11 June 2008 11:24  |
KarSc wrote:
> Hi all,
> workspace .
> . but it doesn't if I try to open a specific program . what am I doing
> wrong?
Only textual editors support this.
Dani
> Thanks for ur help
> Kar
> programs.)
> editor ID: C:\Program Files\Scintilla Text Editor\SciTE.exe
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.06078 seconds
