Home » Eclipse Projects » Eclipse Platform » Plug-in specified entries
Plug-in specified entries [message #33319] Thu, 15 May 2003 11:24 Go to next message
It seems that plugin-specified entries seem to be defined in the plugin.xml
files and added through the extension point. Could anyone please confirm
that plugin-specified entries are not persisted and added at plug-in startup
time by the extension point?
Thanks in advance for your help.
Re: Plug-in specified entries [message #34227 is a reply to message #33319] Thu, 15 May 2003 16:21 Go to previous messageGo to next message
Originally posted by: knut_radloff.oti.com
"Eric" <echaland@ca.ibm.com> wrote in message news:ba0bea$e2c$1@rogue.oti.com...
> Hello,
Which extension point are you referring to? It is not clear what kind of entries you mean.
Knut
Re: Plug-in specified entries [message #35596 is a reply to message #34227] Fri, 16 May 2003 09:17 Go to previous messageGo to next message
It's the com.ibm.etools.xmlutility.catalogContributor extension point (see
com.ibm.etools.struts for an example). We don't use it, so it's not in our
plugin.xml. Instead we programmatically add entries to the XML Catalog.
These entries don't persist themselves. I was wondering if this is the
expected behaviour since all the other entries seem to be populated using
the catalogContributor extension point.
Thanks for your help
"Knut Radloff" <knut_radloff@oti.com> wrote in message
news:ba0ss9$v10$1@rogue.oti.com...
> > Hello,
plugin.xml
startup
entries you mean.
> Knut
Re: Plug-in specified entries [message #44499 is a reply to message #35596] Thu, 22 May 2003 15:26 Go to previous message
Can't help you there. There are IBM newsgroups for the WebSphere products where you may get help.
Knut
"Eric" <echaland@ca.ibm.com> wrote in message news:ba2och$dqc$1@rogue.oti.com...
> > > Hello,
> plugin.xml
> startup
> entries you mean.
> > Knut
Previous Topic:Have a external tool run two commands - possible?
Next Topic:Plugin Dependancy
Current Time: Fri Jul 04 18:16:31 EDT 2025
Powered by FUDForum. Page generated in 0.02804 seconds
