Home » Eclipse Projects » Eclipse Platform » Select editor to open by file inspection
Select editor to open by file inspection [message #329013] Tue, 10 June 2008 10:41 Go to next message
I'd like to select editor based on file inspection. Is there an
extension point for this and can it be used together with ContentTypes?
/Ola
Re: Select editor to open by file inspection [message #329083 is a reply to message #329013] Thu, 12 June 2008 05:14 Go to previous message
Ola Spjuth wrote:
You need to define your own content type that uses a describer. You can
then declare your editor to work for your own content type.
Dani
> Cheers,
> /Ola
Previous Topic:delete action as object contribution ...
Next Topic:AutoAssist & Jar problem
Current Time: Sat Jul 26 10:06:59 EDT 2025
Powered by FUDForum. Page generated in 0.03210 seconds
