Exclude classes from product export [message #329011] |
Tue, 10 June 2008 10:07  |
I have excluded some classes from build path (as they don't compile) in
Eclipse, but when exporting using the Eclipse Product Export Wizard, the
files are added and I get errors. I assume I need to specify this in
build.properties, but I can't figure out how. Now it looks like:
source.. = src/
output.. = bin/
bin.includes = META-INF/,\
jar/batik-awt-util.jar,\
+ more
What do I need to add in order to exclude a package from the export (so
it is not even compiled into .)? I found some options in eclipse help
but can't get it to work, and need some help which is relevant for me:
exclude.. = src/my/package/
src.excludes = src/my/package/
bin.excludes = src/my/package/
Thanks a lot,
/Ola Spjuth
Re: Exclude classes from product export [message #329104 is a reply to message #329011] |
Thu, 12 June 2008 14:19  |
The excludes are not applied to the javac call but rather are used when
gathering everything to be jarred.
The only way I can think of to exclude something from the compile would
be to rename the file (.java.exclude) before the compile and restore it
later.
You can do this using customBuildCallbacks :
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. pde.doc.user/guide/tasks/pde_custom_callbacks.htm
Use the targets pre.@dot and post.compile.@dot
-Andrew
https://bugs.eclipse.org/bugs/show_bug.cgi?id=105631
Ola Spjuth wrote:
> source.. = src/
> output.. = bin/
> + more
> Thanks a lot,
> /Ola Spjuth
FUDForum. Page generated in 0.02971 seconds
