Home » Eclipse Projects » Eclipse Platform » [DataBinding] How to bind a List/ListViewer multi selection
[DataBinding] How to bind a List/ListViewer multi selection [message #328981] Mon, 09 June 2008 15:42 Go to next message
Originally posted by: MeLene3.gmail.com
I'm using eclipse 3.3.
I've a List with SWT.MULTI and an attached ListViewer with a
ObservableListContentProvider/ObservableMapLabelProvider. How is the best
way to bind the selection to an ArrayList in my domain?
-Lene
Re: [DataBinding] How to bind a List/ListViewer multi selection [message #328985 is a reply to message #328981] Mon, 09 June 2008 17:03 Go to previous message
You need 3.4 to make this happen but the databinding from 3.4 is
compatible with SWT 3.3. Fetch the sources from CVS and you are done.
You also get a lot new things for free then (e.g. Tree-Support, ...) :-)
Lene schrieb:
> Hi
> I'm using eclipse 3.3. I've a List with SWT.MULTI and an attached
> ListViewer with a
> best way to bind the selection to an ArrayList in my domain?
> Thanks
> -Lene
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Plugin dev
Next Topic:[DataBinding] Connect Databinding Error Message with Eclipse Forms
Current Time: Sat Jul 19 03:16:24 EDT 2025
Powered by FUDForum. Page generated in 0.03596 seconds
