Home » Eclipse Projects » SWTBot » SWTBot fails with"swtbottestapplication" could not be found in the registry
SWTBot fails with"swtbottestapplication" could not be found in the registry [message #33316] Thu, 23 April 2009 22:56 Go to next message
My swtbot test is failing with :
!SESSION 2009-04-24 12:35:33.207
eclipse.buildId=unknown
java.version=1.6.0_10
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_AU
Framework arguments: -version 3 -port 4297 -testLoaderClass
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestLoade r
-loaderpluginname org.eclipse.jdt.junit.runtime -classNames
com.mgl.yearendtax.userinterface.application.swtbot.FundMana gerViewerTest
-application org.eclipse.swtbot.eclipse.core.swtbottestapplication
-product com.mgl.bfs.desktop.BFSIntegratedDesktop -testpluginname
Command-line arguments: -os win32 -ws win32 -arch x86 -version 3 -port
-product com.mgl.bfs.desktop.BFSIntegratedDesktop -data
C:\workspace/../junit-workspace -dev
file:C:/workspace/.metadata/.plugins/org.eclipse.pde.core/pd e-junit/dev.properties
-os win32 -ws win32 -arch x86 -testpluginname
!ENTRY org.eclipse.osgi 4 0 2009-04-24 12:35:34.176
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application
"org.eclipse.swtbot.eclipse.core.swtbottestapplication" could not be found
in the registry. The applications available are:
com.mgl.bfs.desktop.application, org.eclipse.equinox.app.error,
org.eclipse.pde.junit.runtime.uitestapplication,
org.eclipse.pde.junit.runtime.legacytestapplication,
org.eclipse.pde.junit.runtime.coretestapplication,
org.eclipse.pde.junit.runtime.coretestapplicationnonmain.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
I've seen a similar post previous and it was suggested that the target
platform did not contain
org.eclipse.swtbot.eclipse.core_2.0.0.204-dev.jar. Mine does.
I also saw that the final fix was to set the execution environment to java
1.6, however mine is already 1.6. Anyone have any ideas?
Re: SWTBot fails with"swtbottestapplication" could not be found in the registry [message #33551 is a reply to message #33316] Fri, 24 April 2009 03:36 Go to previous messageGo to next message
I had such an error too when I automated SWTBot build & test.
But now I don't know anymore what the reason was for that error.
Maybe this approach helps you to discover the reason, if it works running
from Eclipse, but not from command-line:
Run the test in debug mode in Eclipse and set a breakpoint very early. In
the debug perspective there is a debug view which shows the process. Right
click on it and select "Properties" from the context menu. Then you see
the start command including all the parameters. Compare it against the
ones you use.
If the problem occurs in Eclipse, then I suggest to download SWTBot from
its repository: svn co
http://dev.eclipse.org/svnroot/technology/org.eclipse.swtbot /trunk swtbot
Follow /swtbot/org.eclipse.swtbot.releng/readme.txt to materialize
workspace and set your target platform to that workspace. Then run
"org.eclipse.swtbot.eclipse.finder.test" as "SWTBot Test". This should
work. Compare now the working instance with the one which throws the
error, to find why it occurs.
When this is fixed, it normally does not trouble ever again (my
experience).
Re: SWTBot fails with"swtbottestapplication" could not be found in the registry [message #33710 is a reply to message #33316] Fri, 24 April 2009 12:16 Go to previous messageGo to next message
> found in the registry. The applications available are:
Probably you do not have org.eclipse.swtbot.eclipse.core in the target
eclipse.
-- Ketan
Re: SWTBot fails with"swtbottestapplication" could not be found in the registry [message #529846 is a reply to message #33710] Tue, 27 April 2010 09:05 Go to previous message
Hi Ketan!
> the target platform did not contain
> environment to java 1.6, however mine is already 1.6.
As I have the same problem I would be interessted in the problems solution as well ...
kind regards, Markus
Previous Topic:SWTBot
Next Topic:Is there no more eclipse spy-bot view?
Current Time: Fri Jul 18 18:28:22 EDT 2025
Powered by FUDForum. Page generated in 0.03437 seconds
