Home » Eclipse Projects » Eclipse Platform » Can decorators modify tooltips
Can decorators modify tooltips [message #328937] Fri, 06 June 2008 18:34 Go to next message
I have a label provider for a TreeViewer that implements
ILightWeightLabelProvider. I wanted to alter or possibly overwrite the
tooltip based on the status of the decorator. Is this possible?
I tried converting my label provider to extend ColumnLabelProvider but it
doesn't seem to work when I pass it in to the DecoratingLabelProvider.
Even if it did, it doesn't appear there is an api for the decorator to
update the tooltip.
The thinking was that I wanted to give users some extra information/help
based on the status of an object. Is there a better way to achieve this?
Re: Can decorators modify tooltips [message #328945 is a reply to message #328937] Sat, 07 June 2008 11:43 Go to previous messageGo to next message
Does this one help[1]. I didn't had time to port in 3.4 but it should
work. If it does could you please comment on the bug and tells what
problems you faced. I'd like to resolve this issue in 3.5 and add a
implementation to JFace.
Tom
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=182216
> it doesn't seem to work when I pass it in to the
> DecoratingLabelProvider. Even if it did, it doesn't appear there is an
> api for the decorator to update the tooltip.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Can decorators modify tooltips [message #329071 is a reply to message #328945] Thu, 12 June 2008 00:25 Go to previous messageGo to next message
Tom, I'll do that. On a quick glance through the code, I don't see how
the tool tip can be affected by the decoration status, but I will try to
get something working and comment that bug.
Re: Can decorators modify tooltips [message #329074 is a reply to message #329071] Thu, 12 June 2008 03:04 Go to previous messageGo to next message
The information for the tooltip is always requested before it is shown
to the user so there's no special asyn-decoration needed if only the
text shown should change.
Tom
Re: Can decorators modify tooltips [message #329113 is a reply to message #329074] Thu, 12 June 2008 18:42 Go to previous messageGo to next message
I've done the following:
1) Added your DecoratingCellLabelProvider to a workspace plugin and put it
in a org.eclipse.jface.viewers package
2) Changed the references to DecorationContext.RESOURCE_MANAGER_KEY to
"DecorationContext.RESOURCE_MANAGER_KEY" since my 3.3 version of
DecorationContext did not have that String defined
3) Created an ILabelProvider that extends ColumnLabelProvider
- Created overrides for getToolTipText and getToolTipImage
4) enabled tooltips with the ColumnViewerToolTipSupport.enableFor(viewer)
Results:
- decorators work as they did before
- tooltips now show up
Problem:
- I may be missing something stupid, but I don't see how the
ColumnLabelProvider can see what decorations were added. My decoration is
expensive, so I don't want to re-do it here. I was thinking there would
be an addition to the ILabelDecorator or ILightweightLabelDecorator that
allowed me to decorate or overwrite the tooltip.
Re: Can decorators modify tooltips [message #329117 is a reply to message #329113] Fri, 13 June 2008 03:47 Go to previous messageGo to next message
Hi John,
I'm not so familiar with decorators. You are asking how to cache the
result for the getToolTipText/getToolTipImage instead of calculating it
every time?
Tom
> it in a org.eclipse.jface.viewers package
> Results:
> Problem: - I may be missing something stupid, but I don't see how the
> is expensive, so I don't want to re-do it here. I was thinking there
> would be an addition to the ILabelDecorator or
> ILightweightLabelDecorator that allowed me to decorate or overwrite the
> tooltip.
Re: Can decorators modify tooltips [message #329128 is a reply to message #329117] Fri, 13 June 2008 09:24 Go to previous messageGo to next message
I like what you've done on getting tools tips, base image and base labels
for an object and that all seems to fit well in the label provider. The
decorator is nice because it is run in the background and in my case
checks on the status of all the objects (a series of database queries and
file accesses) and decorates the text and labels appropriately. While I
have that status information in the decorator code, I would like to be
able to modify the tooltip to tell the user how to address the specific
status issue. I think this would be better than
a) persisting the status in the decorator code or my object
b) Getting access to the decorator text, deciphering it, and modifying the
tooltip through the label provider.
Now that I understand bug 182216 (which did fix the first of my two
problems), should I open a new bug to request adding a new method to the
decorator interfaces?
Re: Can decorators modify tooltips [message #329130 is a reply to message #329128] Fri, 13 June 2008 09:56 Go to previous message
Yes please file a bug and cc me on it.
Tom
> labels for an object and that all seems to fit well in the label
> provider. The decorator is nice because it is run in the background and
> in my case checks on the status of all the objects (a series of database
> queries and file accesses) and decorates the text and labels
> appropriately. While I have that status information in the decorator
> code, I would like to be able to modify the tooltip to tell the user how
> to address the specific status issue. I think this would be better than
> the tooltip through the label provider.
Previous Topic:3.4rc4, manual build failed
Next Topic:eclipse prog launch failure, binaries,toolchain
Current Time: Sat Jul 26 00:51:57 EDT 2025
Powered by FUDForum. Page generated in 0.08427 seconds
