Home » Eclipse Projects » Eclipse Platform » fastview position
fastview position [message #328871] Thu, 05 June 2008 12:09
Is it possible to programmatically determine where a fastview will open on
the screen (top, bottom, right side, left side)?
I know I can use
layout.addFastView(String viewID, float ratio)
where ratio determines how much of the screen the fastview will occupy;
however, it doesn't specify where the fastview should appear.
Chad
Previous Topic:Can i tile editors programmatically?
Next Topic:File->Export key binding
Current Time: Fri Jul 18 03:03:10 EDT 2025
Powered by FUDForum. Page generated in 0.42922 seconds
