Home » Archived » OHF » Question on Patient Identity Feed Transaction
Question on Patient Identity Feed Transaction [message #33302] Wed, 29 August 2007 12:20 Go to next message
I am getting the below exception while trying to perform Patient Identity
Feed Transaction using OHF API.
Exception in thread "AWT-EventQueue-1" java.lang.Error: Unresolved
compilation problem:
Syntax error on token "==", = expected
org.eclipse.ohf.hl7v2.core.conformance.CPDocument.getProfile (CPDocument.java:230)
org.eclipse.ohf.ihe.common.hl7v2.mllpclient.Client.setConfor manceProfile(Client.java:495)
It seems there is some assert statement problem in the class :
org.eclipse.ohf.hl7v2.core.conformance.CPDocument.java
in the jar file : org.eclipse.ohf.hl7v2.core_0.2.0.jar
public CPConformanceProfile getProfile() {
// compiler errors? See readme.txt in <package>/Resources
assert documentType == DOCUMENT_TYPE_PROFILE;
return (CPConformanceProfile) content;
Its using the assert statement, I am running in the Java 1.5 version,
there is no problem in compiling
But it gives above problem during run time. I am testing the ClientPixFeed
which uses XML file
"ADT-A04(register outpatient).XML" for setting the conformance profile as
below code.
InputStream cpStream = new
FileInputStream(PixFeedConfiguration.CPROFILE_PATH);
pixFeed.setConformanceProfile(cpStream);
cpStream.close();
I have already checked the below URL
http://www.cis.upenn.edu/~matuszek/cit594-2004/Pages/eclipse -faq.html ,
But it doesnot resolve with Java 1.5 version.
Can you please provide any solution for this.
Umesh
Re: Question on Patient Identity Feed Transaction [message #33337 is a reply to message #33302] Fri, 31 August 2007 11:43 Go to previous message
Umesh,
As you observed we have seen the assert error before in installations
and in all cases to date, the documentation we provided has corrected
the error. I am not able to reproduce the problem in 1.5.
Has anyone else reading the newsgroup found another solution?
For pix, it is not necessary to use the conformance profile. I expect
you can continue by implementing a method to default common HL7 fields
rather than rely on the CP.
Sondra
> Identity Feed Transaction using OHF API.
> compilation problem: Syntax error on token "==", = expected
> at
> at
> ClientPixFeed which uses XML file "ADT-A04(register outpatient).XML" for
> setting the conformance profile as below code.
> cpStream.close();
> Umesh
Re: Question on Patient Identity Feed Transaction [message #581124 is a reply to message #33302] Fri, 31 August 2007 11:43 Go to previous message
Umesh,
Sondra
> at
> at
> cpStream.close();
> Umesh
Previous Topic:Question on Patient Identity Feed Transaction
Next Topic:MESA10501Test.java fails while setting the value for QPD-3-5
Current Time: Thu Jul 17 22:20:04 EDT 2025
Powered by FUDForum. Page generated in 0.05881 seconds
