| Setting parameters via API [message #328811] |
Thu, 24 January 2008 16:53  |
Originally posted by: pmills.systemcore.ca
I'm missing something that I suspect must be obvious. Using the report
engine API, I have no problem running and rendering a report. I also see
calls to find out all kinds of information about report parameters through
the IGetParameterDefinitionTask. What I don't see is the mechanism for
setting a parameter.
Let's say I schedule a report to run every Sunday night to calculate the
past week's activity. In my scheduler code (Java), I know the start and
end times, which I want to map to '?' parameters in my SQL. What chain of
events has to happen?
| Re: Setting parameters via API [message #344469 is a reply to message #339362] |
Fri, 25 January 2008 08:46  |
Jason Weathersby wrote:
> In the report engine api the run task and the runandrendertask have
> methods that use task.setParameterValue(s)
> either use task.setParameterValue(parmname, parmvalue)
> task.setParameterValues(parmmap);
Thanks! I'll have a look in that direction.
(A "BIRT Cookbook" would be wonderful. There's a big contrast between the
helpfulness of the report design tutorials and the bare API listings in the
programming sections of Eclipse help books.)
| Re: Setting parameters via API [message #344544 is a reply to message #339362] |
| Re: Setting parameters via API [message #344620 is a reply to message #339437] |
| Re: Setting parameters via API [message #348608 is a reply to message #339437] |
FUDForum. Page generated in 0.05758 seconds
