Home » Eclipse Projects » Eclipse Platform » $HOME/.eclipse/org.eclipse.platform_3.3.0_XXXXXXXXX - What formula is used?
$HOME/.eclipse/org.eclipse.platform_3.3.0_XXXXXXXXX - What formula is used? [message #328749] Tue, 03 June 2008 11:15 Go to next message
Originally posted by: jason.polychronopulos.nxp.com
Hi All,
I have been generating the platform.xml dynamically for eclipse to
integrate eclipse plugins with our automated tooling environment.
I use the $HOME/eclipse directory as I can keep the eclipse install read
only and only modify platform.xml in a users environment.
However in eclipse version 3.3.0 things changed and some numbers where
added to the $HOME/.eclipse/org.eclipse.platform_3.3.0_XXXXXXXXX directory.
Thus I can no longer be sure what the directory structure I need to create
is.
I have seen in the following numbers so far on different sites around the
world with the exact same build of eclipse 3.3.2 (m20080221-1800):
(However the number seams quite stable on each site across different
servers.)
org.eclipse.platform_3.3.0_442142533
org.eclipse.platform_3.3.0_935758283
org.eclipse.platform_3.3.0_348091664
Please can someone tell me how this number is derived?
Can I predict what it will be?
Can I include the platform.xml from another "user writable" location,
where I will always know the path?
Many Thanks,
Jason
Re: $HOME/.eclipse/org.eclipse.platform_3.3.0_XXXXXXXXX - What formula is used? [message #328804 is a reply to message #328749] Wed, 04 June 2008 06:19 Go to previous messageGo to next message
Hi, I would like to check that I have posted this to the appropriate group?
Best Regards,
Jason
Re: $HOME/.eclipse/org.eclipse.platform_3.3.0_XXXXXXXXX - What formula is used? [message #328899 is a reply to message #328804] Fri, 06 June 2008 05:27 Go to previous message
Hi All,
I have now found how I can get eclipse to create the .eclipse directory
without the user seeing any output:
eclipse -initialize -noSplash
I can now create and list the dir name before the user has started eclipse.
This now solves my problem.
Best
Previous Topic:want MultiTextEdit to undo at once
Next Topic:Project Management
Current Time: Thu Jul 17 22:10:11 EDT 2025
Powered by FUDForum. Page generated in 0.05293 seconds
