Home » Eclipse Projects » Eclipse Platform » [Fwd: Re: EventLoopProgressMonitor.isCanceled produce a strange refresh]
[Fwd: Re: EventLoopProgressMonitor.isCanceled produce a strange refresh] [message #328732] |
Tue, 03 June 2008 04:20  |
Originally posted by: laurent.legoff.geensy.com
this message have been posted in emf newsgroup first.
Pplease have you got an answer for that problem?
thanks for help
laurent
-------- Message original --------
Sujet: Re: EventLoopProgressMonitor.isCanceled produce a strange refresh
Date: Mon, 02 Jun 2008 16:48:25 +0200
De: Laurent Le Goff <laurent.legoff@geensy.com>
Organisation: EclipseCorner
Forum :: eclipse.tools.emf
Références: <g210pk$fka$1@build.eclipse.org>
Hi all,
I don't know if it is an EMF bug or platform eclipse bug. But I try
here. When there is a long running task that take a transaction Lock
*sometimes* when Lock try to uiSafeAcquire(boolean) there's an
indirect refresh or runEventLoop, this is indirectly due to the dialog
box displaying current blocking running task that block UI Event. This
can cause a infinite loop in the event loop or a warning in the error
log (ColumnViewer.isBusy).
Where is the bug, in EMF or in my code or in EventLoopProgressMonitor
class, I'm lost.
thanks in avance
Laurent
see stack traces below:
Display.readAndDispatch() line: 3293
EventLoopProgressMonitor.runEventLoop() line: 123
EventLoopProgressMonitor.isCanceled() line: 97
ThreadJob.isCanceled(IProgressMonitor) line: 132
ThreadJob.joinRun(IProgressMonitor) line: 167
ImplicitJobs.begin(ISchedulingRule, IProgressMonitor, boolean)
line: 87
JobManager.beginRule(ISchedulingRule, IProgressMonitor) line:
225
Lock.uiSafeAcquire(boolean) line: 403
org.eclipse.equinox.launcher.Main at localhost:1563
Thread [main] (Suspended)
OS.WaitMessage() line: not available [native method]
Display.sleep() line: 4070
EventDetailsDialog(Window).runEventLoop(Shell) line: 821
EventDetailsDialog(Window).open() line: 796
EventDetailsDialog.open() line: 184
EventDetailsDialogAction.run() line: 91
LogView$12.doubleClick(DoubleClickEvent) line: 394
StructuredViewer$1.run() line: 799
SafeRunner.run(ISafeRunnable) line: 37
Platform.run(ISafeRunnable) line: 857
JFaceUtil$1.run(ISafeRunnable) line: 46
SafeRunnable.run(ISafeRunnable) line: 199
TreeViewer(StructuredViewer).fireDoubleClick(DoubleClickEven t)
line: 797
TreeViewer(AbstractTreeViewer).handleDoubleSelect(SelectionE vent) line:
1387
StructuredViewer$4.widgetDefaultSelected(SelectionEvent) line:
1173
OpenStrategy.fireDefaultSelectionEvent(SelectionEvent) line: 237
OpenStrategy.access$0(OpenStrategy, SelectionEvent) line: 234
OpenStrategy$1.handleEvent(Event) line: 295
EventTable.sendEvent(Event) line: 66
Tree(Widget).sendEvent(Event) line: 938
Display.runDeferredEvents() line: 3682
line: 87
225
TransactionalEditingDomainImpl.acquire(InternalTransaction)
line: 512
TransactionalEditingDomainImpl.activate(InternalTransaction)
line: 440
TransactionImpl.start() line: 176
TransactionalEditingDomainImpl.startTransaction(boolean, Map)
line: 356
TransactionalEditingDomainImpl.runExclusive(Runnable) line: 255
GceContentProvider(TransactionalAdapterFactoryContentProvide r).run(RunnableWithResult)
line: 70
GceContentProvider(TransactionalAdapterFactoryContentProvide r).inputChanged(Viewer,
Object, Object) line: 157
TableViewer(ContentViewer).setInput(Object) line: 247
TableViewer(StructuredViewer).setInput(Object) line: 1606
BundlesView(Gce21BrowsingViewPart).adjustInputAndSetSelectio n(Object)
line: 531
BundlesView(Gce21BrowsingViewPart).selectionChanged(IWorkben chPart,
ISelection) line: 707
PageSelectionService(AbstractSelectionService).firePostSelec tion(IWorkbenchPart,
ISelection) line: 179
PageSelectionService(AbstractSelectionService).setActivePart (IWorkbenchPart)
line: 289
WorkbenchPagePartList.fireActivePartChanged(IWorkbenchPartRe ference,
IWorkbenchPartReference) line: 59
WorkbenchPagePartList(PartList).setActivePart(IWorkbenchPart Reference)
line: 126
WorkbenchPage.setActivePart(IWorkbenchPart) line: 3402
WorkbenchPage.requestActivation(IWorkbenchPart) line: 2946
ViewPane(PartPane).requestActivation() line: 265
ViewPane(PartPane).handleEvent(Event) line: 229
Composite(Widget).sendEvent(Event) line: 938
Composite(Widget).sendEvent(int, Event, boolean) line: 962
Composite(Widget).sendEvent(int) line: 943
Shell.setActiveControl(Control) line: 1273
Shell.WM_MOUSEACTIVATE(int, int) line: 2015
Shell(Control).windowProc(int, int, int, int) line: 3713
Shell(Canvas).windowProc(int, int, int, int) line: 291
Shell(Decorations).windowProc(int, int, int, int) line: 1554
Shell.windowProc(int, int, int, int) line: 1753
Display.windowProc(int, int, int, int) line: 4364
OS.DefWindowProcW(int, int, int, int) line: not available
[native method]
OS.DefWindowProc(int, int, int, int) line: 2260
Composite(Scrollable).callWindowProc(int, int, int, int) line:
77
Composite(Control).windowProc(int, int, int, int) line: 3760
[native method]
77
[native method]
77
[native method]
77
[native method]
Tree.callWindowProc(int, int, int, int) line: 1450
Tree.windowProc(int, int, int, int) line: 5368
OS.CallWindowProcW(int, int, int, int, int) line: not available
[native method]
OS.CallWindowProc(int, int, int, int, int) line: 2179
Tree.callWindowProc(int, int, int, int) line: 1541
Tree(Control).windowProc(int, int, int, int) line: 3760
Tree.windowProc(int, int, int, int) line: 5370
OS.PeekMessageW(MSG, int, int, int, int) line: not available
[native method]
OS.PeekMessage(MSG, int, int, int, int) line: 2769
Display.readAndDispatch() line: 3288
Workbench.runEventLoop(Window$IExceptionHandler, Display) line:
2389
Workbench.runUI() line: 2353
Workbench.access$4(Workbench) line: 2219
Workbench$4.run() line: 466
Realm.runWithDefault(Realm, Runnable) line: 289
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor)
line: 461
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor)
line: 149
IDEApplication.start(IApplicationContext) line: 106
EclipseAppHandle.run(Object) line: 169
EclipseAppLauncher.runApplication(Object) line: 106
EclipseAppLauncher.start(Object) line: 76
EclipseStarter.run(Object) line: 363
EclipseStarter.run(String[], Runnable) line: 176
NativeMethodAccessorImpl.invoke0(Method, Object, Object[])
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
Method.invoke(Object, Object...) line: 597
Main.invokeFramework(String[], URL[]) line: 508
Main.basicRun(String[]) line: 447
Main.run(String[]) line: 1173
Main.main(String[]) line: 1148
<not responding>
<not responding>
waiting for: EventManager$EventThread (id=22)
Object.wait(long) line: not available [native method]
EventManager$EventThread(Object).wait() line: 485
EventManager$EventThread.getNextEvent() line: 355
EventManager$EventThread.run() line: 293
<not responding>
waiting for: EventManager$EventThread (id=24)
<not responding>
waiting for: OfflineCachingStorage$CacheFlushJob (id=114)
OfflineCachingStorage$CacheFlushJob(Object).wait() line: 485
OfflineCachingStorage$CacheFlushJob.run(IProgressMonitor) line:
238
Worker.run() line: 55
Thread [Worker-1] (Suspended)
owns: TransactionImpl (id=106)
waiting for: Object (id=105)
ThreadJob.joinRun(IProgressMonitor) line: 189
line: 87
225
line: 512
line: 440
line: 356
TransactionalAdapterFactoryContentProvider.run(RunnableWithR esult) line:
70
TransactionalAdapterFactoryContentProvider.inputChanged(View er,
BasicExplorerContentProvider$1.run(IProgressMonitor) line: 202
<not responding>
waiting for: TaskQueue (id=113)
TimerThread.mainLoop() line: 509
TimerThread.run() line: 462
<not responding>
waiting for: IndexManager (id=112)
IndexManager(Object).wait() line: 485
IndexManager(JobManager).run() line: 369
Thread.run() line: 619
<not responding>
waiting for: TaskQueue (id=107)
<not responding>
waiting for: DirtyRegionQueue (id=111)
AbstractReconciler$BackgroundThread.run() line: 176
Thread [Worker-2] (Suspended)
owns: TransactionImpl (id=110)
waiting for: Semaphore (id=109)
Semaphore.acquire(long) line: 38
OrderedLock.doAcquire(Semaphore, long) line: 169
OrderedLock.acquire(long) line: 105
OrderedLock.acquire() line: 82
Lock.uiSafeAcquire(boolean) line: 401
line: 512
line: 440
line: 356
TransactionalEditingDomainImpl.broadcastUnbatched(Notificati on)
line: 740
TransactionChangeRecorder.appendNotification(Notification)
line: 293
TransactionChangeRecorder.processResourceNotification(Notifi cation)
line: 254
TransactionChangeRecorder.notifyChanged(Notification) line: 220
XMIResourceImpl(BasicNotifierImpl).eNotify(Notification) line:
247
XMIResourceImpl(ResourceImpl).setModified(boolean) line: 1645
XMIResourceImpl(ResourceImpl).save(OutputStream, Map<?,?>)
line: 1267
XMIResourceImpl(ResourceImpl).save(Map<?,?>) line: 964
EcoreResourceUtil.saveModel(EObject, Map<?,?>) line: 318
EcoreWorkspaceUtil.saveModel(EObject, Map<?,?>) line: 243
EcoreWorkspaceUtil$3.runInWorkspace(IProgressMonitor) line: 260
<not responding>
waiting for: Queue$Wait (id=108)
Queue$Wait.waitFor(long) line: 322
Lock.acquire(long, boolean) line: 273
Lock$AcquireJob.run(IProgressMonitor) line: 762
Thread [Worker-4] (Suspended)
owns: TransactionImpl (id=117)
line: 87
225
line: 512
line: 440
line: 356
70
Thread [Worker-5] (Suspended)
owns: TransactionImpl (id=124)
line: 87
225
line: 512
line: 440
line: 356
70
<not responding>
waiting for: TaskListSaveManager$TaskListSaverJob (id=127)
TaskListSaveManager$TaskListSaverJob(Object).wait() line: 485
TaskListSaveManager$TaskListSaverJob.run(IProgressMonitor)
line: 280
<not responding>
waiting for: TaskQueue (id=120)
<not responding>
Thread.sleep(long) line: not available [native method]
ActivityTimerThread.run() line: 64
<not responding>
waiting for: Queue$Wait (id=119)
<not responding>
waiting for: Queue$Wait (id=123)
Thread [Worker-9] (Suspended)
owns: TransactionImpl (id=130)
line: 87
225
line: 512
line: 440
line: 356
ResourceChangedListener.resourceChanged(IResourceChangeEvent )
line: 38
NotificationManager$2.run() line: 282
<unknown receiving type>(<unknown declaring
type>).broadcastPostChange() <unknown line number>
type>).endOperation(ISchedulingRule, boolean, IProgressMonitor) <unknown
line number>
type>).run(IWorkspaceRunnable, ISchedulingRule, int, IProgressMonitor)
type>).run(IProgressMonitor) <unknown line number>
<not responding>
waiting for: WorkerPool (id=122)
WorkerPool.sleep(long) line: 185
WorkerPool.startJob(Worker) line: 217
Worker.run() line: 51
Thread [Worker-11] (Suspended)
owns: TransactionImpl (id=129)
waiting for: Semaphore (id=128)
line: 512
line: 440
line: 356
line: 254
247
line: 1267
EcoreWorkspaceUtil$3(InternalWorkspaceJob).run(IProgressMoni tor) line: 38
<not responding>
waiting for: Queue$Wait (id=116)
<not responding>
waiting for: Queue$Wait (id=121)
<not responding>
waiting for: Queue$Wait (id=118)
<not responding>
line: 87
225
StringPoolJob.run(IProgressMonitor) line: 99
<not responding>
waiting for: ReferenceQueue$Lock (id=131)
ReferenceQueue<T>.remove(long) line: 116
MultiThreadedHttpConnectionManager$ReferenceQueueThread.run( )
line: 1082
<not responding>
java.lang.RuntimeException
org.eclipse.jface.viewers.ColumnViewer.isBusy(ColumnViewer.j ava:79)
org.eclipse.jface.viewers.ColumnViewer.update(ColumnViewer.j ava:551)
org.eclipse.ui.navigator.CommonViewer.update(CommonViewer.ja va:428)
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er$ViewerRefresh.refresh(AdapterFactoryContentProvider.java: 480)
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er$ViewerRefresh.run(AdapterFactoryContentProvider.java:451)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
org.eclipse.ui.internal.dialogs.EventLoopProgressMonitor.run EventLoop(EventLoopProgressMonitor.java:123)
org.eclipse.ui.internal.dialogs.EventLoopProgressMonitor.isC anceled(EventLoopProgressMonitor.java:97)
org.eclipse.core.internal.jobs.ThreadJob.isCanceled(ThreadJo b.java:132)
org.eclipse.core.internal.jobs.ThreadJob.joinRun(ThreadJob.j ava:167)
org.eclipse.core.internal.jobs.ImplicitJobs.begin(ImplicitJo bs.java:87)
org.eclipse.core.internal.jobs.JobManager.beginRule(JobManag er.java:225)
org.eclipse.emf.transaction.util.Lock.uiSafeAcquire(Lock.jav a:404)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.acquire(TransactionalEditingDomainImpl.java:512)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.activate(TransactionalEditingDomainImpl.java:440)
org.eclipse.emf.transaction.impl.TransactionImpl.start(Trans actionImpl.java:176)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.startTransaction(TransactionalEditingDomainImpl.java:356 )
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:255)
org.eclipse.emf.transaction.ui.provider.TransactionalAdapter FactoryLabelProvider.run(TransactionalAdapterFactoryLabelPro vider.java:64)
org.eclipse.emf.transaction.ui.provider.TransactionalAdapter FactoryLabelProvider.getText(TransactionalAdapterFactoryLabe lProvider.java:136)
com.geensys.ecl.emf.explorer.BasicExplorerLabelProvider.getT ext(BasicExplorerLabelProvider.java:61)
org.eclipse.ui.internal.navigator.NavigatorContentServiceLab elProvider.findUpdateLabel(NavigatorContentServiceLabelProvi der.java:327)
org.eclipse.ui.internal.navigator.NavigatorContentServiceLab elProvider.updateLabel(NavigatorContentServiceLabelProvider. java:309)
org.eclipse.jface.viewers.DecoratingLabelProvider.updateLabe l(DecoratingLabelProvider.java:345)
org.eclipse.jface.viewers.WrappedViewerLabelProvider.update( WrappedViewerLabelProvider.java:183)
org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:135)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:911)
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:97)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:991)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:466)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2026)
org.eclipse.jface.viewers.StructuredViewer.internalUpdate(St ructuredViewer.java:2009)
org.eclipse.jface.viewers.StructuredViewer.update(Structured Viewer.java:1953)
org.eclipse.jface.viewers.ColumnViewer.update(ColumnViewer.j ava:553)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Re: [Fwd: Re: EventLoopProgressMonitor.isCanceled produce a strange refresh] [message #328733 is a reply to message #328732] |
Tue, 03 June 2008 07:08   |
Laurent,
This question really requires some attention from Christian and the EMF
newsgroup is the place he's most likely to see your question. It looks
like the something is trying to update a view, something is trying to
process a double click, all while a background thread is busy saving a
file. I'll prompt him when I see him online later today...
Laurent Le Goff wrote:
> thanks for help
> laurent
> Hi all,
> class, I'm lost.
> thanks in avance
> Laurent
> line: 87
> 225
> line: 797
> 1387
> 1173
> line: 87
> 225
> line: 512
> line: 440
> line: 356
> line: 70
> line: 531
> line: 289
> line: 126
> [native method]
> 77
> [native method]
> 77
> [native method]
> 77
> [native method]
> 77
> [native method]
> [native method]
> [native method]
> 2389
> line: 461
> line: 149
> <not responding>
> <not responding>
> <not responding>
> <not responding>
> 238
> line: 87
> 225
> line: 512
> line: 440
> line: 356
> 70
> <not responding>
> <not responding>
> <not responding>
> <not responding>
> line: 512
> line: 440
> line: 356
> line: 740
> line: 293
> line: 254
> 247
> line: 1267
> <not responding>
> line: 87
> 225
> line: 512
> line: 440
> line: 356
> 70
> line: 87
> 225
> line: 512
> line: 440
> line: 356
> 70
> <not responding>
> line: 280
> <not responding>
> <not responding>
> <not responding>
> <not responding>
> line: 87
> 225
> line: 512
> line: 440
> line: 356
> line: 38
> line number>
> <not responding>
> line: 512
> line: 440
> line: 356
> line: 254
> 247
> line: 1267
> <not responding>
> <not responding>
> <not responding>
> <not responding>
> line: 87
> 225
> <not responding>
> line: 1082
> <not responding>
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
> Source)
> at
Re: [Fwd: Re: EventLoopProgressMonitor.isCanceled produce a strange refresh] [message #328737 is a reply to message #328733] |
Tue, 03 June 2008 09:06  |
Originally posted by: cdamus.zeligsoft.com
--=-ryLKLW6t/2yDDg8+J8ZP
Content-Type: text/plain; charset=UTF-8
Hi, Ed,
You don't need to prompt me by special channels. I keep up with the
newsgroups as well as I am able, given the multifarious demands on my
time. I keep hoping, also, that others with experience in the EMF
technologies (incl. Transaction) will pitch in some support.
Christian
On Tue, 2008-06-03 at 07:08 -0400, Ed Merks wrote:
> Laurent,
>=20
> This question really requires some attention from Christian and the EMF=20
> newsgroup is the place he's most likely to see your question. It looks=20
> like the something is trying to update a view, something is trying to=20
> process a double click, all while a background thread is busy saving a=20
>=20
>=20
> > Hi,
> > thanks for help
> > laurent
> > Sujet: Re: EventLoopProgressMonitor.isCanceled produce a strange refres=
h
> > R=C3=A9f=C3=A9rences: <g210pk$fka$1@build.eclipse.org>
> > Hi all,
> > class, I'm lost.
> > thanks in avance
> > Laurent
> > line: 87
> > 225
> > line: 797
> > 1387
> > 1173
> > OpenStrategy.fireDefaultSelectionEvent(SelectionEvent) line: 23=
7
> > line: 87
> > 225
> > line: 512
> > line: 440
> > line: 356
> > GceContentProvider(TransactionalAdapterFactoryContentProvide r).run(Runn=
ableWithResult)=20
> > line: 70
> > GceContentProvider(TransactionalAdapterFactoryContentProvide r).inputCha=
nged(Viewer,=20
> > line: 531
> > PageSelectionService(AbstractSelectionService).firePostSelec tion(IWorkb=
enchPart,=20
> > PageSelectionService(AbstractSelectionService).setActivePart (IWorkbench=
Part)=20
> > line: 289
> > line: 126
> > [native method]
> > 77
> > [native method]
> > 77
> > [native method]
> > 77
> > [native method]
> > 77
> > [native method]
> > [native method]
> > [native method]
> > 2389
> > line: 461
> > line: 149
> > <not responding>
> > <not responding>
> > waiting for: EventManager$EventThread (id=3D22)
> > <not responding>
> > waiting for: EventManager$EventThread (id=3D24)
> > <not responding>
> > waiting for: OfflineCachingStorage$CacheFlushJob (id=3D114)
> > 238
> > owns: TransactionImpl (id=3D106)
> > waiting for: Object (id=3D105)
> > line: 87
> > 225
> > line: 512
> > line: 440
> > line: 356
> > TransactionalAdapterFactoryContentProvider.run(RunnableWithR esult) line=
> > 70
> > <not responding>
> > waiting for: TaskQueue (id=3D113)
> > <not responding>
> > waiting for: IndexManager (id=3D112)
> > <not responding>
> > waiting for: TaskQueue (id=3D107)
> > <not responding>
> > waiting for: DirtyRegionQueue (id=3D111)
> > owns: TransactionImpl (id=3D110)
> > waiting for: Semaphore (id=3D109)
> > line: 512
> > line: 440
> > line: 356
> > line: 740
> > line: 293
> > line: 254
> > 247
> > line: 1267
> > <not responding>
> > waiting for: Queue$Wait (id=3D108)
> > owns: TransactionImpl (id=3D117)
> > line: 87
> > 225
> > line: 512
> > line: 440
> > line: 356
> > 70
> > owns: TransactionImpl (id=3D124)
> > line: 87
> > 225
> > line: 512
> > line: 440
> > line: 356
> > 70
> > <not responding>
> > waiting for: TaskListSaveManager$TaskListSaverJob (id=3D127)
> > line: 280
> > <not responding>
> > waiting for: TaskQueue (id=3D120)
> > <not responding>
> > <not responding>
> > waiting for: Queue$Wait (id=3D119)
> > <not responding>
> > waiting for: Queue$Wait (id=3D123)
> > owns: TransactionImpl (id=3D130)
> > line: 87
> > 225
> > line: 512
> > line: 440
> > line: 356
> > line: 38
> > type>).endOperation(ISchedulingRule, boolean, IProgressMonitor) <unknow=
n
> > line number>
> > <not responding>
> > waiting for: WorkerPool (id=3D122)
> > owns: TransactionImpl (id=3D129)
> > waiting for: Semaphore (id=3D128)
> > line: 512
> > line: 440
> > line: 356
> > line: 254
> > 247
> > line: 1267
> > EcoreWorkspaceUtil$3(InternalWorkspaceJob).run(IProgressMoni tor) line: =
38
> > <not responding>
> > waiting for: Queue$Wait (id=3D116)
> > <not responding>
> > waiting for: Queue$Wait (id=3D121)
> > <not responding>
> > waiting for: Queue$Wait (id=3D118)
> > <not responding>
> > line: 87
> > 225
> > <not responding>
> > waiting for: ReferenceQueue$Lock (id=3D131)
> > line: 1082
> > <not responding>
> > at
> > at
> > at
> > at
> > org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er$ViewerRe=
fresh.refresh(AdapterFactoryContentProvider.java:480)=20
> > at
fresh.run(AdapterFactoryContentProvider.java:451)=20
> > at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 =
5)
> > at
> > org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java=
:123)=20
> > at
> > at
> > at
> > org.eclipse.ui.internal.dialogs.EventLoopProgressMonitor.run EventLoop(E=
ventLoopProgressMonitor.java:123)=20
> > at
> > org.eclipse.ui.internal.dialogs.EventLoopProgressMonitor.isC anceled(Eve=
ntLoopProgressMonitor.java:97)=20
> > at
> > at
> > at
> > at
> > org.eclipse.core.internal.jobs.JobManager.beginRule(JobManag er.java:225=
> > at
> > at
> > org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.acquire=
(TransactionalEditingDomainImpl.java:512)=20
> > at
> > org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.activat=
e(TransactionalEditingDomainImpl.java:440)=20
> > at
> > org.eclipse.emf.transaction.impl.TransactionImpl.start(Trans actionImpl.=
java:176)=20
> > at
> > org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.startTr=
ansaction(TransactionalEditingDomainImpl.java:356)=20
> > at
> > org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExcl=
usive(TransactionalEditingDomainImpl.java:255)=20
> > at
> > org.eclipse.emf.transaction.ui.provider.TransactionalAdapter FactoryLabe=
lProvider.run(TransactionalAdapterFactoryLabelProvider.java: 64)=20
> > at
lProvider.getText(TransactionalAdapterFactoryLabelProvider.j ava:136)=20
> > at
> > com.geensys.ecl.emf.explorer.BasicExplorerLabelProvider.getT ext(BasicEx=
plorerLabelProvider.java:61)=20
> > at
> > org.eclipse.ui.internal.navigator.NavigatorContentServiceLab elProvider.=
findUpdateLabel(NavigatorContentServiceLabelProvider.java:32 7)=20
> > at
updateLabel(NavigatorContentServiceLabelProvider.java:309)=2 0
> > at
> > org.eclipse.jface.viewers.DecoratingLabelProvider.updateLabe l(Decoratin=
gLabelProvider.java:345)=20
> > at
> > org.eclipse.jface.viewers.WrappedViewerLabelProvider.update( WrappedView=
erLabelProvider.java:183)=20
> > at
> > at
> > org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeV=
iewer.java:911)=20
> > at
> > org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run=
(AbstractTreeViewer.java:97)=20
> > at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 =
9)
> > at
iewer.java:991)=20
> > at
> > org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(S=
tructuredViewer.java:466)=20
9)
> > at
> > org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.=
java:2026)=20
> > at
> > org.eclipse.jface.viewers.StructuredViewer.internalUpdate(St ructuredVie=
wer.java:2009)=20
> > at
> > org.eclipse.jface.viewers.StructuredViewer.update(Structured Viewer.java=
:1953)=20
> > at
> > at
> > at
> > at
5)
> > at
:123)=20
> > at
> > at
> > at
> > at=20
> > at
> > org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java=
:289)=20
> > at
> > org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:=
461)=20
> > at
> > at
> > org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplica=
tion.java:106)=20
> > at
> > org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.=
java:169)=20
> > at
> > org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplica=
tion(EclipseAppLauncher.java:106)=20
> > at
> > org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ecli=
pseAppLauncher.java:76)=20
> > at
> > org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java=
:363)=20
> > at
:176)=20
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown=20
> > Source)
> > at=20
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.16.0">
</HEAD>
<BODY>
Hi, Ed,<BR>
<BR>
You don't need to prompt me by special channels. I keep up with the newsgroups as well as I am able, given the multifarious demands on my time. I keep hoping, also, that others with experience in the EMF technologies (incl. Transaction) will pitch in some support.<BR>
<BR>
Thanks,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
<FONT COLOR="#000000">Laurent,</FONT>
<FONT COLOR="#000000">This question really requires some attention from Christian and the EMF </FONT>
<FONT COLOR="#000000">newsgroup is the place he's most likely to see your question. It looks </FONT>
<FONT COLOR="#000000">like the something is trying to update a view, something is trying to </FONT>
<FONT COLOR="#000000">process a double click, all while a background thread is busy saving a </FONT>
<FONT COLOR="#000000">file. I'll prompt him when I see him online later today...</FONT>
<FONT COLOR="#000000">Laurent Le Goff wrote:</FONT>
<FONT COLOR="#000000">> Hi,</FONT>
<FONT COLOR="#000000">> this message have been posted in emf newsgroup first.</FONT>
<FONT COLOR="#000000">> Pplease have you got an answer for that problem?</FONT>
<FONT COLOR="#000000">></FONT>
<FONT COLOR="#000000">> thanks for help</FONT>
<FONT COLOR="#000000">> laurent</FONT>
<FONT COLOR="#000000">> -------- Message original --------</FONT>
<FONT COLOR="#000000">> Sujet: Re: EventLoopProgressMonitor.isCanceled produce a strange refresh</FONT>
<FONT COLOR="#000000">> Date: Mon, 02 Jun 2008 16:48:25 +0200</FONT>
<FONT COLOR="#000000">> De: Laurent Le Goff <<A HREF="mailto:laurent.legoff@geensy.com">laurent.legoff@geensy.com</A>></FONT>
<FONT COLOR="#000000">> Organisation: EclipseCorner</FONT>
<FONT COLOR="#000000">> Forum :: eclipse.tools.emf</FONT>
<FONT COLOR="#000000">> Références: <<A HREF="mailto:g210pk$fka$1@build.eclipse.org">g210pk$fka$1@build.eclipse.org</A>></FONT>
<FONT COLOR="#000000">> Hi all,</FONT>
<FONT COLOR="#000000">> I don't know if it is an EMF bug or platform eclipse bug. But I try</FONT>
<FONT COLOR="#000000">> here. When there is a long running task that take a transaction Lock</FONT>
<FONT COLOR="#000000">> *sometimes* when Lock try to uiSafeAcquire(boolean) there's an</FONT>
<FONT COLOR="#000000">> indirect refresh or runEventLoop, this is indirectly due to the dialog</FONT>
<FONT COLOR="#000000">> box displaying current blocking running task that block UI Event. This</FONT>
<FONT COLOR="#000000">> can cause a infinite loop in the event loop or a warning in the error</FONT>
<FONT COLOR="#000000">> log (ColumnViewer.isBusy).</FONT>
<FONT COLOR="#000000">> Where is the bug, in EMF or in my code or in EventLoopProgressMonitor</FONT>
<FONT COLOR="#000000">> class, I'm lost.</FONT>
<FONT COLOR="#000000">> thanks in avance</FONT>
<FONT COLOR="#000000">> Laurent</FONT>
<FONT COLOR="#000000">> see stack traces below:</FONT>
<FONT COLOR="#000000">> Display.readAndDispatch() line: 3293</FONT>
<FONT COLOR="#000000">> EventLoopProgressMonitor.runEventLoop() line: 123</FONT>
<FONT COLOR="#000000">> EventLoopProgressMonitor.isCanceled() line: 97</FONT>
<FONT COLOR="#000000">> ThreadJob.isCanceled(IProgressMonitor) line: 132</FONT>
<FONT COLOR="#000000">> ThreadJob.joinRun(IProgressMonitor) line: 167</FONT>
<FONT COLOR="#000000">> ImplicitJobs.begin(ISchedulingRule, IProgressMonitor, boolean)</FONT>
<FONT COLOR="#000000">> line: 87</FONT>
<FONT COLOR="#000000">> JobManager.beginRule(ISchedulingRule, IProgressMonitor) line:</FONT>
<FONT COLOR="#000000">> 225</FONT>
<FONT COLOR="#000000">> Lock.uiSafeAcquire(boolean) line: 403</FONT>
<FONT COLOR="#000000">> org.eclipse.equinox.launcher.Main at localhost:1563</FONT>
<FONT COLOR="#000000">> Thread [main] (Suspended)</FONT>
<FONT COLOR="#000000">> OS.WaitMessage() line: not available [native method]</FONT>
<FONT COLOR="#000000">> Display.sleep() line: 4070</FONT>
<FONT COLOR="#000000">> EventDetailsDialog(Window).runEventLoop(Shell) line: 821</FONT>
<FONT COLOR="#000000">> EventDetailsDialog(Window).open() line: 796</FONT>
<FONT COLOR="#000000">> EventDetailsDialog.open() line: 184</FONT>
<FONT COLOR="#000000">> EventDetailsDialogAction.run() line: 91</FONT>
<FONT COLOR="#000000">> LogView$12.doubleClick(DoubleClickEvent) line: 394</FONT>
<FONT COLOR="#000000">> StructuredViewer$1.run() line: 799</FONT>
<FONT COLOR="#000000">> SafeRunner.run(ISafeRunnable) line: 37</FONT>
<FONT COLOR="#000000">> Platform.run(ISafeRunnable) line: 857</FONT>
<FONT COLOR="#000000">> JFaceUtil$1.run(ISafeRunnable) line: 46</FONT>
<FONT COLOR="#000000">> SafeRunnable.run(ISafeRunnable) line: 199</FONT>
<FONT COLOR="#000000">> TreeViewer(StructuredViewer).fireDoubleClick(DoubleClickEven t) </FONT>
<FONT COLOR="#000000">> line: 797</FONT>
<FONT COLOR="#000000">> TreeViewer(AbstractTreeViewer).handleDoubleSelect(SelectionE vent) line:</FONT>
<FONT COLOR="#000000">> 1387</FONT>
<FONT COLOR="#000000">> StructuredViewer$4.widgetDefaultSelected(SelectionEvent) line:</FONT>
<FONT COLOR="#000000">> 1173</FONT>
<FONT COLOR="#000000">> OpenStrategy.fireDefaultSelectionEvent(SelectionEvent) line: 237</FONT>
<FONT COLOR="#000000">> OpenStrategy.access$0(OpenStrategy, SelectionEvent) line: 234</FONT>
<FONT COLOR="#000000">> OpenStrategy$1.handleEvent(Event) line: 295</FONT>
<FONT COLOR="#000000">> EventTable.sendEvent(Event) line: 66</FONT>
<FONT COLOR="#000000">> Tree(Widget).sendEvent(Event) line: 938</FONT>
<FONT COLOR="#000000">> Display.runDeferredEvents() line: 3682</FONT>
<FONT COLOR="#000000">> TransactionalEditingDomainImpl.acquire(InternalTransaction)</FONT >
<FONT COLOR="#000000">> line: 512</FONT>
<FONT COLOR="#000000">> TransactionalEditingDomainImpl.activate(InternalTransaction) </FONT>
<FONT COLOR="#000000">> line: 440</FONT>
<FONT COLOR="#000000">> TransactionImpl.start() line: 176</FONT>
<FONT COLOR="#000000">> TransactionalEditingDomainImpl.startTransaction(boolean, Map)</FONT>
<FONT COLOR="#000000">> line: 356</FONT>
<FONT COLOR="#000000">> TransactionalEditingDomainImpl.runExclusive(Runnable) line: 255</FONT>
<FONT COLOR="#000000">> GceContentProvider(TransactionalAdapterFactoryContentProvide r).run(RunnableWithResult) </FONT>
<FONT COLOR="#000000">> line: 70</FONT>
<FONT COLOR="#000000">> GceContentProvider(TransactionalAdapterFactoryContentProvide r).inputChanged(Viewer, </FONT>
<FONT COLOR="#000000">> Object, Object) line: 157</FONT>
<FONT COLOR="#000000">> TableViewer(ContentViewer).setInput(Object) line: 247</FONT>
<FONT COLOR="#000000">> TableViewer(StructuredViewer).setInput(Object) line: 1606</FONT>
<FONT COLOR="#000000">> BundlesView(Gce21BrowsingViewPart).adjustInputAndSetSelectio n(Object) </FONT>
<FONT COLOR="#000000">> line: 531</FONT>
<FONT COLOR="#000000">> BundlesView(Gce21BrowsingViewPart).selectionChanged(IWorkben chPart, </FONT>
<FONT COLOR="#000000">> ISelection) line: 707</FONT>
<FONT COLOR="#000000">> PageSelectionService(AbstractSelectionService).firePostSelec tion(IWorkbenchPart, </FONT>
<FONT COLOR="#000000">> ISelection) line: 179</FONT>
<FONT COLOR="#000000">> PageSelectionService(AbstractSelectionService).setActivePart (IWorkbenchPart) </FONT>
<FONT COLOR="#000000">> line: 289</FONT>
<FONT COLOR="#000000">> WorkbenchPagePartList.fireActivePartChanged(IWorkbenchPartRe ference, </FONT>
<FONT COLOR="#000000">> IWorkbenchPartReference) line: 59</FONT>
<FONT COLOR="#000000">> WorkbenchPagePartList(PartList).setActivePart(IWorkbenchPart Reference) </FONT>
<FONT COLOR="#000000">> line: 126</FONT>
<FONT COLOR="#000000">> WorkbenchPage.setActivePart(IWorkbenchPart) line: 3402</FONT>
<FONT COLOR="#000000">> WorkbenchPage.requestActivation(IWorkbenchPart) line: 2946</FONT>
<FONT COLOR="#000000">> ViewPane(PartPane).requestActivation() line: 265</FONT>
<FONT COLOR="#000000">> ViewPane(PartPane).handleEvent(Event) line: 229</FONT>
<FONT COLOR="#000000">> Composite(Widget).sendEvent(Event) line: 938</FONT>
<FONT COLOR="#000000">> Composite(Widget).sendEvent(int, Event, boolean) line: 962</FONT>
<FONT COLOR="#000000">> Composite(Widget).sendEvent(int) line: 943</FONT>
<FONT COLOR="#000000">> Shell.setActiveControl(Control) line: 1273</FONT>
<FONT COLOR="#000000">> Shell.WM_MOUSEACTIVATE(int, int) line: 2015</FONT>
<FONT COLOR="#000000">> Shell(Control).windowProc(int, int, int, int) line: 3713</FONT>
<FONT COLOR="#000000">> Shell(Canvas).windowProc(int, int, int, int) line: 291</FONT>
<FONT COLOR="#000000">> Shell(Decorations).windowProc(int, int, int, int) line: 1554</FONT>
<FONT COLOR="#000000">> Shell.windowProc(int, int, int, int) line: 1753</FONT>
<FONT COLOR="#000000">> Display.windowProc(int, int, int, int) line: 4364</FONT>
<FONT COLOR="#000000">> OS.DefWindowProcW(int, int, int, int) line: not available</FONT>
<FONT COLOR="#000000">> [native method]</FONT>
<FONT COLOR="#000000">> OS.DefWindowProc(int, int, int, int) line: 2260</FONT>
<FONT COLOR="#000000">> Composite(Scrollable).callWindowProc(int, int, int, int) line:</FONT>
<FONT COLOR="#000000">> 77</FONT>
<FONT COLOR="#000000">> Composite(Control).windowProc(int, int, int, int) line: 3760</FONT>
<FONT COLOR="#000000">> Tree.callWindowProc(int, int, int, int) line: 1450</FONT>
<FONT COLOR="#000000">> Tree.windowProc(int, int, int, int) line: 5368</FONT>
<FONT COLOR="#000000">> OS.CallWindowProcW(int, int, int, int, int) line: not available</FONT>
<FONT COLOR="#000000">> OS.CallWindowProc(int, int, int, int, int) line: 2179</FONT>
<FONT COLOR="#000000">> Tree.callWindowProc(int, int, int, int) line: 1541</FONT>
<FONT COLOR="#000000">> Tree(Control).windowProc(int, int, int, int) line: 3760</FONT>
<FONT COLOR="#000000">> Tree.windowProc(int, int, int, int) line: 5370</FONT>
<FONT COLOR="#000000">> OS.PeekMessageW(MSG, int, int, int, int) line: not available</FONT>
<FONT COLOR="#000000">> OS.PeekMessage(MSG, int, int, int, int) line: 2769</FONT>
<FONT COLOR="#000000">> Display.readAndDispatch() line: 3288</FONT>
<FONT COLOR="#000000">> Workbench.runEventLoop(Window$IExceptionHandler, Display) line:</FONT>
<FONT COLOR="#000000">> 2389</FONT>
<FONT COLOR="#000000">> Workbench.runUI() line: 2353</FONT>
<FONT COLOR="#000000">> Workbench.access$4(Workbench) line: 2219</FONT>
<FONT COLOR="#000000&qu
Current Time: Tue Jul 15 23:41:32 EDT 2025
Powered by FUDForum. Page generated in 0.06774 seconds
