Uninstall plugin [message #328731] |
Tue, 03 June 2008 03:16  |
Originally posted by: egidijus.vaisnora.nomagiclt.com
What is correct way to remove plugins from the dropins folder?
I am installing my plugins by adding link files. For p2 platform, I am placing link files into dropins folder and plugins are
installed. However, when I remove these link files on my custom uninstall, my plugins still are loaded - regardless if "-clean"
is added in "eclipse.ini" or not. And only when I remove my plugins entries from the "bundles.info" file, my plugins are not
loaded by Eclipse platform. However to edit "bundles.info" file is not recommened...
Re: Uninstall plugin [message #328800 is a reply to message #328756] |
Wed, 04 June 2008 02:04  |
I am adding into dropins not into plugins and adding/removing "link" files, but not the plugins instance, and technical removal
of link files doesn't help!
julien wrote:
> technicly just remove it from C:\eclipse\plugin .
>> placing link files into dropins folder and plugins are installed.
>> plugins still are loaded - regardless if "-clean" is added in
>> the "bundles.info" file, my plugins are not loaded by Eclipse
FUDForum. Page generated in 0.05665 seconds
