Home » Eclipse Projects » Eclipse Platform » Source -> Format menu
Source -> Format menu [message #328718] Mon, 02 June 2008 14:25 Go to next message
I created a source formatter for my plugin, attached to the source
viewer and I can execute it from a menu of my own; However, I'd like it
to be run from the Source -> Format menu that it appears in the project
explorer... how can this be done?
thanks in advance
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Source -> Format menu [message #329054 is a reply to message #328718] Wed, 11 June 2008 09:38 Go to previous messageGo to next message
Lorenzo Bettini wrote:
> Hi
> it to be run from the Source -> Format menu that it appears in the
> project explorer... how can this be done?
You need to define the command, the key binding and the action in your
plugin.xml. Take a look at "org.eclipse.jdt.ui.edit.text.java.format" in
/org.eclipse.jdt.ui/plugin.xml.
Dani
> thanks in advance
> Lorenzo
Re: Source -> Format menu [message #329385 is a reply to message #329054] Sun, 22 June 2008 09:40 Go to previous messageGo to next message
>> Hi
thanks, I'll take a look!
I was only surprised that "Source" is not one of the standard menus (I
mean, I didn't find an id for that, while there's one for edit, etc.),
or am I wrong?
cheers
Lorenzo
Re: Source -> Format menu [message #329855 is a reply to message #329054] Tue, 08 July 2008 11:50 Go to previous message
>> Hi
I actually haven't found any example of this; however, I'd need to be
able to associate an action to the "Source -> Format" menu that is in
the context menu in the package explorer; this shows for every file, but
it says that the action is not enabled for my files...
any doc or example on-line, please?
thanks in advance
Lorenzo
Previous Topic:Removing Import export from pop-up Menu
Next Topic:Contribution to Eclipse toolbar is not hidden on switching the perspective
Current Time: Thu Oct 23 06:26:27 EDT 2025
Powered by FUDForum. Page generated in 0.27014 seconds
