Home » Eclipse Projects » Eclipse Platform » Can I open several workspaces with one running Eclipse instance
Can I open several workspaces with one running Eclipse instance [message #328680] Mon, 02 June 2008 03:08 Go to next message
is it possible to start / view several workspaces at the same time in one
running Eclipse instance?
Switching between workspaces takes a long time while starting several
Eclipse instance consume a lot of memory.
Best regards, Lars
Re: Can I open several workspaces with one running Eclipse instance [message #328683 is a reply to message #328680] Mon, 02 June 2008 04:36 Go to previous messageGo to next message
Why don't you just launch Eclipse installation several times with
different workspaces?
BR,
Danail
Lars Vogel wrote:
> Best regards, Lars
Re: Can I open several workspaces with one running Eclipse instance [message #328694 is a reply to message #328683] Mon, 02 June 2008 07:18 Go to previous messageGo to next message
Hi Danail,
starting several Eclipse instance consume a lot of memory.
Best regards, Lars
"Danail Nachev" <d.nachev@prosyst.bg> wrote in message
news:g20bf4$nmb$1@build.eclipse.org...
> BR,
> Danail
> Lars Vogel wrote:
>> Best regards, Lars
Re: Can I open several workspaces with one running Eclipse instance [message #328695 is a reply to message #328694] Mon, 02 June 2008 07:40 Go to previous messageGo to next message
Unfortunately there is no other way if you want to work with multiple
workspaces at once.
Lars Vogel wrote:
> Hi Danail,
> Best regards, Lars
>> BR,
>> Danail
>> Lars Vogel wrote:
>>> Hi,
>>> Best regards, Lars
Re: Can I open several workspaces with one running Eclipse instance [message #328697 is a reply to message #328694] Mon, 02 June 2008 07:45 Go to previous messageGo to next message
Are you familiar with working sets? This way you have 1 workspace and
configure it for different projects you work on. The others are hidden.
Tom
Lars Vogel schrieb:
> Hi Danail,
> Best regards, Lars
>> BR,
>> Danail
>> Lars Vogel wrote:
>>> Hi,
>>> Best regards, Lars
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Can I open several workspaces with one running Eclipse instance [message #328701 is a reply to message #328695] Mon, 02 June 2008 09:58 Go to previous messageGo to next message
Hi Danail,
ok. Thank you. Best regards, Lars
news:g20m89$ktv$1@build.eclipse.org...
> workspaces at once.
> Lars Vogel wrote:
>> Hi Danail,
>> Best regards, Lars
>>> BR,
>>> Danail
>>> Lars Vogel wrote:
>>>> Hi,
>>>> one
>>>> Best regards, Lars
Re: Can I open several workspaces with one running Eclipse instance [message #328702 is a reply to message #328697] Mon, 02 June 2008 10:01 Go to previous message
Hi Tom,
Yes I'm using working sets already. Still, as I'm developing some really
different things I like to have them also separated in Workspaces, e.g. my
private developments vrs. my work developments.
But opening several Eclipse instances is not really a big problem, I just
wanted to be sure that I'm not missing something.
Thank you, Lars
Best regards, Lars
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:g20mh5$m0s$1@build.eclipse.org...
> Tom
> Lars Vogel schrieb:
>> Hi Danail,
>> Best regards, Lars
>>> BR,
>>> Danail
>>> Lars Vogel wrote:
>>>> Hi,
>>>> one
>>>> Best regards, Lars
Previous Topic:Redrawing wizard pages
Next Topic:Virtual JFace Viewers - add(Objects[])
Current Time: Fri Nov 21 18:38:47 EST 2025
Powered by FUDForum. Page generated in 0.07301 seconds
