Home » Eclipse Projects » Eclipse Platform » Not able to right click the project tree view on hte left pane in eclipse 3.3.2
Not able to right click the project tree view on hte left pane in eclipse 3.3.2 [message #328677] Mon, 02 June 2008 01:24
Originally posted by: shantanu_chitale.persistent.co.in
For automation testing I am using rational robot 7.0.1. I have following
code to identify the tree object at runtime
For i = 1 to 10
Window SetContext, GStrEclipseMainWindowCaption, ""
Result = SQAFindObject("Type=TreeView;ObjectIndex=" & i)
If Result = 0 Then
vRet = ""
intResult = SQAGetProperty("Type=TreeView;ObjectIndex=" & i,
"Visible", vRet)
If vRet = -1 Then
Call SQAGetProperty("Type=TreeView;ObjectIndex=" & i,
"hWnd", vValue)
vValue = GStrTreeViewId & vValue & ";\;ItemText="
GetTreeViewObject = vValue
Exit For
End If
End If
Next
From the above code I'm able to get the tree view handle at runtime and
can right click the project in tree view.
This particular code works for eclipse 3.3.0 but does not work on 3.3.2.
Can anyone help me out in this. Also what is the difference between
eclipse 3.3.0 and 3.3.2.
Previous Topic:debugplugin.exec stop suddenly without reason
Next Topic:[DataBinding] Using ControlDecoration in data binding snippets
Current Time: Sun Aug 31 00:21:23 EDT 2025
Powered by FUDForum. Page generated in 0.02341 seconds
