Home » Eclipse Projects » Eclipse Platform » Companion Library on Mac
Companion Library on Mac [message #328676] Sun, 01 June 2008 22:09 Go to next message
Originally posted by: krolmobile.yahoo.com
I am running Mac OSX 10.5.2. I have downloaded Eclipse, but when I try to
run the executable I get the following error message:
The Eclipse executable launcher was unable to locate its companion shared
library.
Not sure what to do from here...
Thanks!
Re: Companion Library on Mac [message #328726 is a reply to message #328676] Mon, 02 June 2008 16:52 Go to previous message
What version of Eclipse did you try? To get this did you simply unzip
and try running, or did you do something to the install?
One way to fix it would be to edit the
Eclipse.app/Contents/MacOS/eclipse.ini file and add the following lines
to the beginning:
--launcher.library
/path/to/eclipse/plugins/org.eclipse.equinox.launcher.carbon .macosx_1.0.100.v20080509-1800/eclipse_1114.so
(With the proper version numbers corresponding to your install).
-Andrew
> to run the executable I get the following error message:
> shared library.
> Thanks!
Previous Topic:Ant Editor Tweaking
Next Topic:Re: Showing two editors (Horizontal or vertical split) programmatically
Current Time: Sun Jul 27 07:26:57 EDT 2025
Powered by FUDForum. Page generated in 0.04020 seconds
