Home » Eclipse Projects » Eclipse Platform » org.eclipse.ui.commands defaultHandler isA?
org.eclipse.ui.commands defaultHandler isA? [message #328597] Tue, 27 May 2008 21:20 Go to next message
The doc for the extension point org.eclipse.ui.commands, has:
defaultHandler -
The default handler for this command (see the org.eclipse.ui.bindings
extension point). If no other handler is active, this handler will be
active. This handler will conflict with other handler definitions that
specify no activeWhen conditions. If you are creating an
IExecutableExtension, you can use the defaultHandler element instead.
But what kind of value does it want? A class name? ID for some other
markup? Something else altogether?
John.
Re: org.eclipse.ui.commands defaultHandler isA? [message #328922 is a reply to message #328597] Fri, 06 June 2008 14:07 Go to previous message
That should be an org.eclipse.core.commands.IHandler or preferably a
subclass of org.eclipse.core.commands.AbstractHandler
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Enabling Handlers based on Perspective
Next Topic:Need help to get ContextMenu for Shell Trim
Current Time: Sun Aug 31 03:28:51 EDT 2025
Powered by FUDForum. Page generated in 0.03554 seconds
