Home » Eclipse Projects » Eclipse Platform » Refresh resource after external alteration to file
Refresh resource after external alteration to file [message #328487] Mon, 26 May 2008 10:11 Go to next message
I have code that has to save via a path (String). So, I create my own
FileOutputStream that writes the file to the workspace (not via IFile),
and close the stream. The workspace is obviously not aware of this, and
I need to hit refresh before using the file (I use a CommonNavigator).
Is there some way I can locate the file in the workspace by name or
external (non-workspace) path, so I can get a handle to the IFile and
call "refresh" programmatically? Or could someone recommend another
strategy so that the resource is refreshed automatically on external
modification?
.../Ola
Re: Refresh resource after external alteration to file [message #328498 is a reply to message #328487] Mon, 26 May 2008 12:55 Go to previous messageGo to next message
Use IWorkspaceRoot.getFileForLocation() to get the IFile and do a
refreshLocal() on that.
- Prakash
Eclipse Tips: http://blog.cypal-solutions.com
Eclipse Search: http://www.cypal.in/eclipsesearch
Ola Spjuth wrote:
> modification?
> Cheers,
> .../Ola
Re: Refresh resource after external alteration to file [message #328636 is a reply to message #328487] Thu, 29 May 2008 04:14 Go to previous messageGo to next message
Ola Spjuth wrote:
> IFile), and close the stream. The workspace is obviously not aware of
> this, and I need to hit refresh before using the file (I use a
> CommonNavigator). Is there some way I can locate the file in the
> workspace by name or external (non-workspace) path, so I can get a
> handle to the IFile and call "refresh" programmatically? Or could
> someone recommend another strategy so that the resource is refreshed
> automatically on external modification?
The simplest for you would be to use file buffers. You can get it by
path and it will even handle the load and save operations for you.
Dani
> Cheers,
> .../Ola
Re: Refresh resource after external alteration to file [message #328642 is a reply to message #328498] Thu, 29 May 2008 10:03 Go to previous message
Originally posted by: kosta.bea.com
Here is a conversion routine that I had to write a while back for
getting IFile given File:
public static IFile getWorkspaceFile( final File f )
final IWorkspace ws = ResourcesPlugin.getWorkspace();
final IWorkspaceRoot wsroot = ws.getRoot();
final IPath path = new Path( f.getAbsolutePath() );
final IFile[] wsFiles = wsroot.findFilesForLocation( path );
if( wsFiles.length > 0 )
return wsFiles[ 0 ];
return null;
- Konstantin
Previous Topic:How to find the updated buffer in Compare Editor?
Next Topic:Working sets loosing projects
Current Time: Tue Jul 22 02:42:46 EDT 2025
Powered by FUDForum. Page generated in 0.08187 seconds
