Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] signing problem
Re: [buckminster-dev] signing problem [message #1721107] Sat, 23 January 2016 19:06
On 1/23/2016 1:31 PM, denstar wrote:
> It might help to troubleshoot what's going on a bit more. Since the
> error is saying the target directory doesn't exist, perhaps start there.
> Can you ssh in and verify that ${eclipse.staging.area} exists?
> That seems to be this directory:
> /home/data/users/mkuppe//home/data/httpd/download-staging.priv/rt/ecf
> Seems a little like the path might be incorrect... should it be:
Yes, that's correct...the full path
seems wrong to me, although both parts (/home/data/users/mkuppe and
/home/data/httpd/download-staging.priv/rt/ecf are present).
What's confusing about all this is that we haven't changed the
configuration significantly (i.e. we haven't changed paths, logins, in
the builder etc). Things just started to fail in this way without
obviously related changes on our builder's side.
> Maybe? I only sign my own stuff, and not for eclipse, so I dunno what
> the structure is.
> For debugging, I just took a gander at this (the latest, tho probably
> pretty close to what's being used):
> https://github.com/eclipse/buckminster/blob/master/org.eclipse.buckminster.jarprocessor/src/org/eclipse/buckminster/jarprocessor/antscript/signing.ant
Yes...good idea. I did take a look at this and couldn't detect any
obvious problems, although I think that the version that's on master is
significantly different (newer) than the version we are currently using
for build.
> You could see if any of those properties have been changed or some such.
> Could be what Ed said, and the directory didn't get mounted on that server.
> HIH,
Thanks for the help.
Scott
Previous Topic:Re: [buckminster-dev] signing problem
Next Topic:Re: [buckminster-dev] signing problem
Current Time: Thu Jul 10 10:26:16 EDT 2025
Powered by FUDForum. Page generated in 0.05508 seconds
