Home » Eclipse Projects » Buckminster dev » [buckminster-dev] signing problem
[buckminster-dev] signing problem [message #1721096] Sat, 23 January 2016 11:56 Go to next message
ECF has been using Buckminster and the Eclipse signing service to sign
our builds for some time.
We recently did a successful release build and then a few days later
when we ran our head build again we get the error below. As far as I
can tell, this was done without any changes to parameter values. It
seems to indicate some problem with the file/path input variables
Any insights about what is going on here? Or how to debug?
INFO: [end org.eclipse.ecf.sdk:eclipse.feature$3.12.1.qualifier#copy.plugins]
Action org.eclipse.ecf.sdk:eclipse.feature$3.12.1.qualifier#site.signed using 'up to date' policy MAPPER: Rebuild needed: File count(0) < expected(272)
init actor: ant[org.eclipse.ecf.sdk:eclipse.feature$3.12.1.qualifier#site.signed]
buildFileId=buckminster.signing
targets=sign.jars
INFO: [start org.eclipse.ecf.sdk:eclipse.feature$3.12.1.qualifier#site.signed]
Prerequisite alias = action.requirements
Product alias = action.output
Product base = ${buckminster.output}/site.signed/
target.arch=x86_64
buckminster.component=org.eclipse.ecf.sdk
workspace.root=/opt/hudson/jobs/R-HEAD-sdk.feature/workspace
buckminster.temp=/opt/hudson/jobs/R-HEAD-sdk.feature/workspace/buckminster.temp/org.eclipse.ecf.sdk_3.12.1-eclipse.feature/temp
buckminster.home=/opt/hudson/jobs/R-HEAD-sdk.feature/workspace/projects/org.eclipse.ecf.sdk/
buckminster.output=/opt/hudson/jobs/R-HEAD-sdk.feature/workspace/buckminster.output/org.eclipse.ecf.sdk_3.12.1-eclipse.feature
localhost=ecf-builds.osuosl.org
buckminster.component.type=eclipse.feature
buckminster.version=3.12.1.qualifier
target.nl=en_US
target.ws=gtk
eclipse.home=/opt/hudson/tools/hudson.plugins.buckminster.BuckminsterInstallation/Buckminster_4.3/buckminster
target.os=linux
target.location=/opt/hudson/jobs/R-HEAD-sdk.feature/workspace/targetPlatformPath
[ant] Queueing site_1169116494.zip for signing
ERROR: org.eclipse.core.runtime.CoreException: /opt/hudson/tools/hudson.plugins.buckminster.BuckminsterInstallation/Buckminster_4.3/buckminster/configuration/org.eclipse.osgi/bundles/27/1/.cp/org/eclipse/buckminster/jarprocessor/antscript/signing.ant:174: server indicated an error: scp: /home/data/users/mkuppe//home/data/httpd/download-staging.priv/rt/ecf: No such file or directory
at org.eclipse.buckminster.ant.AntRunner.handleInvocationTargetException(AntRunner.java:167)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:322)
at org.eclipse.buckminster.ant.actor.AntActor.internalPerform(AntActor.java:254)
at org.eclipse.buckminster.core.actor.AbstractActor.perform(AbstractActor.java:195)
at org.eclipse.buckminster.core.internal.actor.PerformManager$DirectActionInvocation.execute(PerformManager.java:143)
at org.eclipse.buckminster.core.internal.actor.PerformManager.internalPerform(PerformManager.java:454)
at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:293)
at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:305)
at org.eclipse.buckminster.core.commands.Perform.internalRun(Perform.java:108)
at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(WorkspaceCommand.java:86)
at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(AbstractCommand.java:200)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:343)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:284)
at org.eclipse.buckminster.cmdline.Headless.start(Headless.java:358)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: /opt/hudson/tools/hudson.plugins.buckminster.BuckminsterInstallation/Buckminster_4.3/buckminster/configuration/org.eclipse.osgi/bundles/27/1/.cp/org/eclipse/buckminster/jarprocessor/antscript/signing.ant:174: server indicated an error: scp: /home/data/users/mkuppe//home/data/httpd/download-staging.priv/rt/ecf: No such file or directory
at org.apache.tools.ant.taskdefs.optional.ssh.AbstractSshMessage.waitForAck(AbstractSshMessage.java:132)
at org.apache.tools.ant.taskdefs.optional.ssh.ScpToMessage.sendFileToRemote(ScpToMessage.java:229)
at org.apache.tools.ant.taskdefs.optional.ssh.ScpToMessage.doSingleTransfer(ScpToMessage.java:160)
at org.apache.tools.ant.taskdefs.optional.ssh.ScpToMessage.execute(ScpToMessage.java:144)
at org.apache.tools.ant.taskdefs.optional.ssh.Scp.upload(Scp.java:337)
at org.apache.tools.ant.taskdefs.optional.ssh.Scp.execute(Scp.java:226)
Re: [buckminster-dev] signing problem [message #1721102 is a reply to message #1721096] Sat, 23 January 2016 15:23 Go to previous messageGo to next message
Most of the infrastructure was restarted a couple of days ago, and as so
often, not everything restarts correctly. Maybe some mount that you
require got lost. HIPP6 has been a disaster on a couple of occasions.
Buckminster 4.3 is perhaps a bit dated with the increasing expexctations
of Java 8.
IIRC there have been SSH issues and patches. Maybe SCP is affected.
Ed Willink
> INFO: [end
> Action
> init actor:
> targets=sign.jars
> INFO: [start
> target.arch=x86_64
> target.nl=en_US
> target.ws=gtk
> target.os=linux
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> Caused by:
> at
> at
> at
> at
> at
> at
Re: [buckminster-dev] signing problem [message #1721103 is a reply to message #1721102] Sat, 23 January 2016 16:16 Go to previous message
Hi Ed.
Thanks, I wasn't aware of this possibility. I don't know if this matters,
but we've been seeing this problem for ~ a week (had our own restart this
week as well but it's doing the same thing).
Where would you say the best place to open a bug would be? Do you know if
there an appropriate place for the signing service specifically?
Scott
> Hi
> of Java 8.
> Regards
> Ed Willink
>> INFO: [end
>> Action
>> expected(272)
>> init actor:
>> targets=sign.jars
>> INFO: [start
>> target.arch=x86_64
>> target.nl=en_US
>> target.ws=gtk
>> target.os=linux
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> Caused by:
>> at
>> at
>> at
>> at
>> at
>> at
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@xxxxxxxx
> To change your delivery options, retrieve your password, or unsubscribe
> from this list, visit
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Previous Topic:[buckminster-dev] adding build plugin to headless eclipse (2)
Next Topic:Re: [buckminster-dev] signing problem
Current Time: Sat Nov 08 15:07:17 EST 2025
Powered by FUDForum. Page generated in 0.05307 seconds
