Newbie - simple project in Eclipse, I can't figure this out [message #1720920] |
Thu, 21 January 2016 15:05  |
I've spent approx 30 hours trying to figure this out and I'm totally stuck. I'm going to try to net it out as much as possible, in the chance that my basic workflow and understanding might be flawed.
I have a very simple project in Eclipse that I generated as a "Dynamic Web Project"; it has a single file in the webcontent folder, called "index.jsp" which emits the text "Hello World".
I create a local git for this, and then I commit/push to my remote git repo.
Next, I want to try an experiment - can I completely wipe out my project in Eclipse, then pull it back down from the remote repo and have it back to where I was before I wiped it out?
I do this, but when I clone the remote git then tell it to import project using "Project Import Wizard" (as a dynamic web project) -- I get this error:
Connecting Git team provider failed. See log for details.
Error connecting project test-project2, no Git repositories found
OK, so that doesn't work. Let me just import it as a project, skip the fancy "import wizard". I do this, and it imports fine.
But, now the project is flawed. There is no /src folder and it is also complaining about "broken single root rule".
So, basically I have no idea how to push a project a remote git, then share it with someone else or bring it back to myself as a new project, without having failures.
FUDForum. Page generated in 0.04256 seconds
