Home » Eclipse Projects » Eclipse Platform » importing the javaeditor example
importing the javaeditor example [message #328415] Sat, 24 May 2008 04:57 Go to next message
I've installed the sdk examples and I imported the javaeditor plugin
example (by using the wizard Import -> Plugin and fragments); however, I
get many compilation errors (and the main one seems to be in the
manifest file: 'Bundle-SymbolicName' header is required in
org.eclipse.ui.examples.javaeditor/META-INF/MANIFEST.MF line 1)...
am I doing something wrong?
what is the correct way to import that plugin?
thanks in advance
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: importing the javaeditor example [message #328433 is a reply to message #328415] Sat, 24 May 2008 08:37 Go to previous messageGo to next message
That example is a touch out of date. It uses the old bundle metadata
mechanism (supported prior to version 3.0). AFAIK, it doesn't even have
a manifest.mf file.
You might try to fix it up, but I suspect that you're going to run into
a lot more problems.
Wayne
On Sat, 2008-05-24 at 10:57 +0200, Lorenzo Bettini wrote:
> Hi
> thanks in advance
> Lorenzo
Re: importing the javaeditor example [message #328470 is a reply to message #328433] Mon, 26 May 2008 04:58 Go to previous messageGo to next message
> a manifest.mf file.
There's nothing to fix. Just because it's old and not ported to the new
runtime story doesn't mean that the sample doesn't work. Installing the
sample via Welcome page works fine and also importing the plug-in and
running it works for me.
Dani
> Wayne
>> Hi
>> thanks in advance
>> Lorenzo
Re: importing the javaeditor example [message #328471 is a reply to message #328415] Mon, 26 May 2008 04:58 Go to previous messageGo to next message
> Hi
> I get many compilation errors (and the main one seems to be in the
Yes ;-) Simply install the Sample via Help > Welcome. I just tried this
and there is no error reported. Also, importing the binary project works
for me but attaching the source seems broken.
Dani
> thanks in advance
> Lorenzo
Re: importing the javaeditor example [message #328716 is a reply to message #328471] Mon, 02 June 2008 14:24 Go to previous message
>> Hi
yes, that seems to work fine; probably it downloads it from another
source... probably the documentation of the examples should be updated
though...
thanks
Lorenzo
Previous Topic:How to fit the wizard for different resolution montiors
Next Topic:Plugins & Target Platform Help!
Current Time: Fri Jul 18 02:12:57 EDT 2025
Powered by FUDForum. Page generated in 0.09580 seconds
