Home » Eclipse Projects » Eclipse Platform » classes appearing twice in my plugin
classes appearing twice in my plugin [message #328377] Fri, 23 May 2008 10:45 Go to next message
Originally posted by: subs._nospam_consertum.com
I have just noticed that all of the classes in my plugins are appearing
twice in the plugin.jar. For example, my com.xyz.plugin.jar contains
bin
|- com
|- xyz
|- plugin
|- Activator.class
com
|- xyz
|- plugin
|- Activator.class
That is, it contains the same .class files in both
bin/com/xyz/plugin/... AND com/xyz/plugin/...
Any ideas why this is happening?
Derek
Re: classes appearing twice in my plugin [message #328381 is a reply to message #328377] Fri, 23 May 2008 11:18 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Could you give a copy of your build.properties?
Derek wrote:
> bin
> |- com
> |- xyz
> |- plugin
> |- Activator.class
> com
> |- xyz
> |- plugin
> |- Activator.class
> Thanks
Rich Kulp
Re: classes appearing twice in my plugin [message #328387 is a reply to message #328381] Fri, 23 May 2008 12:24 Go to previous messageGo to next message
Here's the contents of my build.properties file:
source.. = src/
output.. = bin/
bin.includes = plugin.xml,\
plugin.properties,\
icons/,\
META-INF/,\
bin/
src.includes = src/,\
plugin.xml,\
plugin.properties,\
icons/,\
META-INF/,\
bin/
Rich Kulp wrote:
> Derek wrote:
>> appearing twice in the plugin.jar. For example, my com.xyz.plugin.jar
>> contains
>> bin
>> |- com
>> |- xyz
>> |- plugin
>> |- Activator.class
>> com
>> |- xyz
>> |- plugin
>> |- Activator.class
>> Thanks
Derek
Re: classes appearing twice in my plugin [message #328389 is a reply to message #328387] Fri, 23 May 2008 12:51 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
Remove the bin/ entry from bin.includes and src.includes.
- Konstantin
Re: classes appearing twice in my plugin [message #328397 is a reply to message #328389] Fri, 23 May 2008 15:53 Go to previous messageGo to next message
> - Konstantin
Hmmm. Now my plugin doesn't work at all. I get class load failures.
I checked the plugin.jar and it has a com directory, but doesn't have a
bin directory. I'm sure I'm missing something here.
Derek
Re: classes appearing twice in my plugin [message #328398 is a reply to message #328397] Fri, 23 May 2008 16:47 Go to previous message
>> - Konstantin
Check your plugin's MANIFEST.MF file. If there is a Bundle-ClassPath
entry, it should include ".". I suspect "bin" might have been added
instead. (If there's no Bundle-ClassPath entry, then that's fine since
"." is the default)
Previous Topic:Binding the attribute of a bean object wrapped in a WritableValue object
Next Topic:FileLink in console with a external file
Current Time: Mon Jul 21 22:29:03 EDT 2025
Powered by FUDForum. Page generated in 0.05351 seconds
