Home » Eclipse Projects » Eclipse Platform » Why is it needed for java bean to implement property change support
Why is it needed for java bean to implement property change support [message #328349] Thu, 22 May 2008 11:49 Go to next message
jface databinding framwork has provided a lot of help classes, such as
BeansObservables and WritableValue. Why is it still needed for java bean
to implement property change support, such as
public class Message extends ModelObject {
public class ModelObject {
private final PropertyChangeSupport propertyChangeSupport = new
PropertyChangeSupport(
this);
public void addPropertyChangeListener(PropertyChangeListener listener) {
propertyChangeSupport.addPropertyChangeListener(listener);
public void addPropertyChangeListener(String propertyName,
propertyChangeSupport.addPropertyChangeListener(propertyName , listener);
public void removePropertyChangeListener(PropertyChangeListener listener)
propertyChangeSupport.removePropertyChangeListener(listener) ;
public void removePropertyChangeListener(String propertyName,
propertyChangeSupport.removePropertyChangeListener(propertyN ame,
listener);
protected void firePropertyChange(String propertyName, Object oldValue,
Object newValue) {
propertyChangeSupport.firePropertyChange(propertyName, oldValue,
newValue);
protected void fireIndexedPropertyChange(String propertyName, int index,
Object oldValue, Object newValue) {
propertyChangeSupport.fireIndexedPropertyChange( propertyName, index,
oldValue, newValue);
Re: Why is it needed for java bean to implement property change support [message #328350 is a reply to message #328349] Thu, 22 May 2008 13:17 Go to previous messageGo to next message
> <<snip>>
DataBinding is based around the observer pattern. If there is no
property change support on your bean, then BeansObservables has no way
to add property change listeners, and therefore cannot detect when your
bean properties change.
If property change support is not critical to your application, you can
use PojoObservables instead. PojoObservables are identical to
BeansObservables except that they do not use property change listeners.
Matthew
[DataBinding] Re: Why is it needed for java bean to implement property change support [message #328351 is a reply to message #328349] Thu, 22 May 2008 12:19 Go to previous messageGo to next message
In Eclipse 3.4, there is a new class,
org.eclipse.core.databinding.beans.PojoObservables, that supports
creating observables on objects that do not fire property change events.
The limitation, of course, is that the framework isn't notified if the
underlying objects are changed directly - that's what the property
change events provide. So if your model objects don't do that they can't
tell the data binding framework when their properties have changed.
Hope this helps,
Eric
Re: [DataBinding] Re: Why is it needed for java bean to implement property change support [message #328355 is a reply to message #328351] Thu, 22 May 2008 21:00 Go to previous message
Thanks all of you!
Previous Topic:p2 Installer Issues
Next Topic:How to update an RCP app
Current Time: Thu Jul 17 07:15:06 EDT 2025
Powered by FUDForum. Page generated in 0.04284 seconds
