Home » Eclipse Projects » Eclipse Platform » Programatically Fire a Selection Event
Programatically Fire a Selection Event [message #328232] Mon, 19 May 2008 12:05 Go to next message
Hi there,
I have a bunch of ViewParts created, all implementing the
ISelectionListener interface and registered as selectionListeners. I would
like to programatically fire a selection event from one ViewPart to update
the others, based on a value selected in a ListViewer.
From reading around it appears there are two schools of thought on this -
1. Call Widget.notifyListeners() with an Event as a parameter
or
2. Call Display.post() with an Event as a parameter
I've tried both of these, but my ISelectionListeners are not registering
the selection event. Here is the code I'm currently using:
// Trying to fire a selection event
listViewer.getList().setSelection(0);
Event event = new Event();
event.type = SWT.Selection;
event.widget = listViewer.getList();
listViewer.getList().notifyListeners(SWT.Selection, event);
Has anyone got any idea how to get this working correctly?
I understand I can call setSelection on the listViewer itself, but I don't
have the list of objects at hand to create a meaningful selection here. I
just want to ensure the first item is selected, hence the use of getList().
Thanks!
Maurice
Re: Programatically Fire a Selection Event [message #328238 is a reply to message #328232] Mon, 19 May 2008 13:22 Go to previous messageGo to next message
Apologies for reposting, but somebody else had exactly this problem here:
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg05204.html
Any ideas would be greatly appreciated!
Maurice
Re: Programatically Fire a Selection Event [message #328240 is a reply to message #328232] Mon, 19 May 2008 14:02 Go to previous messageGo to next message
Tell the view's site to setSelectionProvider to your ListViewer.
Something like:
getSite().setSelectionProvider(myListViewer);
You follow up post cites an message that suggests this already. In what
way is setSelectionProvider *not* doing what you need?
You might also consider setting the selection provider to another
implementation of ISelectionProvider. Say, a custom one that suits your
purposes...
Wayne
On Mon, 2008-05-19 at 16:05 +0000, Maurice O\'Connor wrote:
> Hi there,
> or
> Thanks!
> Maurice
Re: Programatically Fire a Selection Event [message #328252 is a reply to message #328240] Tue, 20 May 2008 05:29 Go to previous messageGo to next message
> Something like:
> purposes...
Heya, thanks for the help!
setSelectionProvider works for me. I add the listViewer as a provider,
then the user clicks the items in the list to update other ViewParts, each
of those implementing ISelectionListener and registered using the
Selection Service. eg.
In one ViewPart:
getSite().setSelectionProvider(listViewer);
In the others:
getSite().getPage().addSelectionListener(new
ListISelectionListener());
The ISelectionListeners update correctly except when an item is selected
on the list programmatically. Eg.
In that case I need to fire my own event to trigger the selectionChanged
method in the ISelectionListeners - my problem is figuring out how to do
this.
Maurice
Re: Programatically Fire a Selection Event [message #328256 is a reply to message #328252] Tue, 20 May 2008 08:04 Go to previous messageGo to next message
Maurice,
I think you'd have to create your own SelectionEvent and call
notifyListeners with it.
Maurice O'Connor wrote:
>> Something like:
>> purposes...
> each of those implementing ISelectionListener and registered using the
> In one ViewPart:
> In the others:
> selected on the list programmatically. Eg.
> selectionChanged method in the ISelectionListeners - my problem is
> figuring out how to do this.
> Maurice
Re: Programatically Fire a Selection Event [message #328268 is a reply to message #328252] Tue, 20 May 2008 10:40 Go to previous messageGo to next message
What are you really trying to do?
Do listeners get properly notified when you go through the ListViewer's
API:
listViewer.setSelection(StructuredSelection.EMPTY);
Wayne
On Tue, 2008-05-20 at 09:29 +0000, Maurice O\'Connor wrote:
> > Something like:
> > purposes...
> In one ViewPart:
> In the others:
> this.
> Maurice
Re: Programatically Fire a Selection Event [message #328280 is a reply to message #328268] Tue, 20 May 2008 12:34 Go to previous messageGo to next message
> API:
> Wayne
This will notify ISelectionChangedListeners of the above change. However,
my listeners implement ISelectionListener. I need to notify the
ISelectionListeners by firing a new selection event through the workbench
selection service.
The listViewer is already registered as a SelectionProvider:
Now I must create my own Event and notify its listeners:
listViewer.getList().notifyListeners(SWT.Selection, new Event());
That doesn't work though. There's a nice tutorial here:
http://www.eclipse.org/articles/Article-WorkbenchSelections/ article.html
It says:
"Each workbench window has its own selection service instance. The service
keeps track of the selection in the currently active part and propagates
selection changes to all registered listeners. Such selection events occur
when the selection in the current part is changed or when a different part
is activated. Both can be triggered by user interaction or
programmatically."
I'm trying to work out how to do this programmatically, with little
success so far ;)
Maurice
Re: Programatically Fire a Selection Event [message #328283 is a reply to message #328280] Tue, 20 May 2008 12:50 Go to previous messageGo to next message
Maurice,
I think maybe it needs to be a SelectionEvent. You should also have to
look closely at all the fields that are normally populated and populate
them properly.
Wayne,
Programmatically changing the selection of a widget (or anything else
you do with it) doesn't fire the same events as when the user does that
same thing. This is by design.
>> API:
>> Wayne
> However, my listeners implement ISelectionListener. I need to notify
> the ISelectionListeners by firing a new selection event through the
> workbench selection service.
> It says:
> service keeps track of the selection in the currently active part and
> propagates selection changes to all registered listeners. Such
> selection events occur when the selection in the current part is
> changed or when a different part is activated. Both can be triggered
> by user interaction or programmatically."
> success so far ;)
> Maurice
Re: Programatically Fire a Selection Event [message #328319 is a reply to message #328283] Wed, 21 May 2008 09:42 Go to previous messageGo to next message
> them properly.
notifyListeners(Event event) & getDisplay().post(Event event)
These take only a plain Event as a parameter. So I tried both of these. A
comparison of both a generated event and one of my own creation is below:
Event {type=13 List {} time=32740484 data=null x=0 y=0 width=0 height=0
detail=0}
Event {type=13 List {} time=29613453 data=null x=0 y=0 width=0 height=0
detail=0}
Still not getting through to the SelectionListeners with this. Perhaps I
have registered the listeners incorrectly?
getSite().getPage().addSelectionListener(new ChangeListener(listViewer));
The listViewer is registered in the ViewPart like so:
Maurice
Maurice
Re: Programatically Fire a Selection Event [message #328326 is a reply to message #328319] Wed, 21 May 2008 12:00 Go to previous messageGo to next message
Maurice,
I've never done it so tracing through the calls in each case with the
debugger would be my approach...
>> to look closely at all the fields that are normally populated and
>> populate them properly.
> these. A comparison of both a generated event and one of my own
> creation is below:
> height=0 detail=0}
> height=0 detail=0}
> I have registered the listeners incorrectly?
> Maurice
> Maurice
Re: Programatically Fire a Selection Event [message #328919 is a reply to message #328252] Fri, 06 June 2008 13:41 Go to previous message
Don't get the SWT list ... just call setSelection(*) on your ListViewer
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Extrange behaviours in Ganymedes M7 workbench
Next Topic:How to listen to ActiveEditor changes and is IEditorActionDelegate deprecated?
Current Time: Sun Aug 31 02:15:50 EDT 2025
Powered by FUDForum. Page generated in 0.04448 seconds
