Tableviewer with databinding and inline edit support for boolean [message #328226] |
Mon, 19 May 2008 09:32  |
Originally posted by: lukas.myslivec.com
my tableviewer is bound to a collection (like in the jface databinding
snippet).
i want to add in line edit support. it works great for text ( i have done
it like the example in Snippet013TableViewerEditing ).
now i want to do the same with booleans. when the user clicks the cell it
should change from true to false (an the other why).
i tryed it the following way:
public class InlineCheckboxEditingSupport extends
ObservableValueEditingSupport
private CellEditor cellEditor;
private String propertyName;
* @param viewer
* @param dbc
public InlineCheckboxEditingSupport(ColumnViewer viewer,
DataBindingContext dbc, String propertyName)
super(viewer, dbc);
cellEditor = new CheckboxCellEditor((Composite) viewer.getControl());
this.propertyName = propertyName;
protected CellEditor getCellEditor(Object element)
return cellEditor;
protected IObservableValue doCreateCellEditorObservable(CellEditor
cellEditor)
return SWTObservables.observeSelection(cellEditor.getControl());
protected IObservableValue doCreateElementObservable(Object element,
ViewerCell cell)
return BeansObservables.observeValue(element, propertyName);
But this fails because checkboxcelleditor doesnt provide a control.
any suggestions?
reagards
lukas
Re: Tableviewer with databinding and inline edit support for boolean [message #328251 is a reply to message #328250] |
Tue, 20 May 2008 04:53  |
Hi Lukas,
Could you file a bug against this snippet under Platform/UI and CC me.
I'll then take care that the bug is fixed.
Tom
lukas schrieb:
> Hello,
> thank you very much (booth of you).
> the BooleanCellEditor works greate. i only had to modify the if
> statement in deactivate method otherwise the cell gets empty if i am
> changing the checkbox to the origin value (like from true to false to
> true).
> regards
> lukas
> public class BooleanCellEditor extends CellEditor
> private Button button;
> private ViewerRow row;
> private int index;
> private String restoredText;
> private Image restoredImage;
> private Boolean oldValue;
> * @param parent
> public BooleanCellEditor(Composite parent)
> super(parent);
> * @param parent
> * @param style
> public BooleanCellEditor(Composite parent, int style)
> super(parent, style);
> public LayoutData getLayoutData()
> LayoutData data = super.getLayoutData();
> data.horizontalAlignment = SWT.CENTER;
> data.grabHorizontal = false;
> return data;
> protected Control createControl(Composite parent)
> Font font = parent.getFont();
> Color bg = parent.getBackground();
> button = new Button(parent, getStyle() | SWT.CHECK);
> button.setFont(font);
> button.setBackground(bg);
> button.addKeyListener(new KeyAdapter()
> * (non-Javadoc)
> * * @see
> org.eclipse.swt.events.KeyAdapter#keyReleased(org.eclipse.sw t.events.KeyEvent)
> public void keyReleased(KeyEvent e)
> if (e.character == SWT.ESC)
> fireCancelEditor();
> return button;
> protected Object doGetValue()
> return new Boolean(button.getSelection());
> protected void doSetValue(Object value)
> boolean selection = Boolean.TRUE.equals(value);
> button.setSelection(selection);
> protected void doSetFocus()
> if (button != null)
> button.setFocus();
> protected void deactivate(ColumnViewerEditorDeactivationEvent event)
> super.deactivate(event);
> if (event.eventType ==
> ColumnViewerEditorDeactivationEvent.EDITOR_CANCELED
> || oldValue == button.getSelection()) {
> row.setImage(index, restoredImage);
> row.setText(index, restoredText);
> row = null;
> restoredImage = null;
> restoredText = null;
> public void activate(ColumnViewerEditorActivationEvent activationEvent)
> ViewerCell cell = (ViewerCell) activationEvent.getSource();
> index = cell.getColumnIndex();
> row = (ViewerRow) cell.getViewerRow().clone();
> restoredImage = row.getImage(index);
> restoredText = row.getText(index);
> row.setImage(index, null);
> row.setText(index, ""); //$NON-NLS-1$
> super.activate(activationEvent);
> oldValue = button.getSelection();
> * (non-Javadoc)
> * * @see org.eclipse.jface.viewers.CellEditor#getDoubleClickTimeout()
> protected int getDoubleClickTimeout()
> return 0;
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
FUDForum. Page generated in 0.28559 seconds
