Home » Eclipse Projects » Eclipse Platform » Eclipse version
Eclipse version [message #328220] Mon, 19 May 2008 06:12 Go to next message
Originally posted by: egidijus.vaisnora.nomagiclt.com
What is good way to find out what eclipse version is installed? My code must ensure to integrate properly with Eclipse platform
and when user selects Eclipse install root, I need to decide - if it is 3.4 eclipse and search for "dropins" directory, or it
is earlier Eclipse platform with "plugins" directory?
Re: Eclipse version [message #328224 is a reply to message #328220] Mon, 19 May 2008 09:23 Go to previous messageGo to next message
> must ensure to integrate properly with Eclipse platform and when user
> and search for "dropins" directory, or it is earlier Eclipse platform
Help->About Eclipse Platform
Re: Eclipse version [message #328225 is a reply to message #328220] Mon, 19 May 2008 09:25 Go to previous messageGo to next message
Well, versions prior to 3.4 won't even have a dropins directory, os you
could just look for that and if its there assume you are dealing with 3.4.
The only other idea I have is to look in the features directory for a
directory name that begins with "org.eclipse.platform_3.4" as opposed to
"org.eclipse.platform_3.3"
Hope this helps,
Eric
Re: Eclipse version [message #328229 is a reply to message #328220] Mon, 19 May 2008 10:55 Go to previous messageGo to next message
How about parsing Platform.getProduct().getDescription() ?
Dirk
Re: Eclipse version [message #328237 is a reply to message #328229] Mon, 19 May 2008 13:15 Go to previous messageGo to next message
>> code must ensure to integrate properly with Eclipse platform and when
>> eclipse and search for "dropins" directory, or it is earlier Eclipse
> Dirk
from the formulation of the question, I was under the impression that he
was looking for that information from outside of eclipse. in that case,
looking at the plugin version might be better. another problem might
exist for derived products and might have a different topology on disk
(or even eclipse 3.4 with some shared install)
Laurent Mihalkovic, co-author SWT/JFace in Action (www.manning.com/scarpino)
Re: Eclipse version [message #328249 is a reply to message #328237] Tue, 20 May 2008 02:08 Go to previous message
Exactly, idea is to find Eclipse version, not starting it. And, of course, there is problem with derived products, like RAD,
JBuilder and etc. - for all products I need to specify different integration scenario (my tool helps to integrate product as
plugin for Eclipse, regarding the Eclipse version or derivation )
>> Regards,
>> Dirk
Previous Topic:Intro to using JNI with Eclipse?
Next Topic:Tableviewer with databinding and inline edit support for boolean
Current Time: Mon Jul 21 22:22:48 EDT 2025
Powered by FUDForum. Page generated in 0.27338 seconds
