Home » Eclipse Projects » Eclipse Platform » Hook into the Java refactoring
Hook into the Java refactoring [message #328212] Sun, 18 May 2008 15:59 Go to next message
I'm new to the Eclipse and the Java IDE.
I need to create a plugin that will help me refactor the EMF code and
generation. I have a task the need to rename 50 classes out of 150 that
the eCore generated.
I want to leverage the existing Java refactoring that will trickle
throughout all the projects and will rename all classes and references.
Is there a way for write a plugin that uses the build in refactoring of
the Java code? I can write code to modify the eCore but I need the
corresponding Java classes renamed and all references.
Yigal
Re: Hook into the Java refactoring [message #328213 is a reply to message #328212] Mon, 19 May 2008 00:37 Go to previous message
Hi Yigal,
I'm not sure what you are trying to do. Can't you customize your eCore
model itself to generate the code in the way you want?
Anyways, for refactoring, have a look at the org.eclipse.ltk plugins &
their extensions
- Prakash
Eclipse Tips: http://blog.cypal-solutions.com
Eclipse Search: http://www.cypal.in/eclipsesearch
> Thanks
> Yigal
Previous Topic:template completion (how to)
Next Topic:error starting eclipse with firefox 3
Current Time: Tue Jul 22 13:57:40 EDT 2025
Powered by FUDForum. Page generated in 0.07525 seconds
