Home » Eclipse Projects » Eclipse Platform » workbench hangs after first execution
workbench hangs after first execution [message #328201] Fri, 16 May 2008 16:48 Go to next message
Hi all:
I recently added code to store store some data in the session property.
Everyhting in the app works fine. However, once I exit the application and
tries to restart it, it hangs forever.
But, if I close my plugin project and then exit. I can restart again. The
same is the case when I clear the workspace.
Any ideas?
-Jeevan
Re: workbench hangs after first execution [message #328204 is a reply to message #328201] Sat, 17 May 2008 02:07 Go to previous messageGo to next message
Jeevan wrote:
> Hi all:
> property. Everyhting in the app works fine. However, once I exit the
> application and tries to restart it, it hangs forever. But, if I close
> my plugin project and then exit. I can restart again. The same is the
> Any ideas?
Make a stack dump.
Dani
> -Jeevan
Re: workbench hangs after first execution [message #328207 is a reply to message #328204] Sat, 17 May 2008 10:41 Go to previous messageGo to next message
--------------050909000503080604090607
Jeevan,
Here are some instructions for how to do that.
<http://wiki.eclipse.org/index.php/How_to_report_a_deadlock>
Daniel Megert wrote:
> Jeevan wrote:
>> Hi all:
>> close my plugin project and then exit. I can restart again. The same
>> Any ideas?
> Make a stack dump.
> Dani
>> -Jeevan
<html>
<head>
http-equiv="Content-Type">
</head>
Jeevan,<br>
<br>
Here are some instructions for how to do that.<a
href="http://wiki.eclipse.org/index.php/How_to_report_a_deadlock"><br>
</a>
<blockquote><a
href="http://wiki.eclipse.org/index.php/How_to_report_a_deadlock">http://wiki.eclipse.org/index.php/How_to_report_a_deadlock</a><br>
</blockquote>
<br>
<blockquote cite="mid:g0lsn6$hn1$1@build.eclipse.org" type="cite">Jeevan
wrote:
<br>
<blockquote type="cite">Hi all:
<br>
<br>
and tries to restart it, it hangs forever. But, if I close my plugin
project and then exit. I can restart again. The same is the case when I
<br>
Any ideas?
<br>
</blockquote>
Make a stack dump.
<br>
<br>
Dani
<br>
<blockquote type="cite"><br>
-Jeevan
<br>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------050909000503080604090607--
Re: workbench hangs after first execution [message #328291 is a reply to message #328207] Tue, 20 May 2008 16:40 Go to previous messageGo to next message
the tool proved to be very useful.
It helped me debug to the source of the problem
-jm
Re: workbench hangs after first execution [message #328330 is a reply to message #328291] Wed, 21 May 2008 12:46 Go to previous messageGo to next message
And the winner is?
Dani
> -jm
Re: workbench hangs after first execution [message #328334 is a reply to message #328330] Wed, 21 May 2008 15:15 Go to previous message
mine is a GMF application which can have multiple projects and I have a
piece of code which automatically update a session property with the
active project. This had a bug. At the time the application opened the
active project was not set and for some reasons this led to the workbench
not opening at all... and since I use org.eclipse.ui.ide.workbench to run
my application, there was no exception reported
-Jeevan
Previous Topic:Rounded section and CCombo controls
Next Topic:Run As JUnit Plug-in Test
Current Time: Fri Jul 18 20:37:08 EDT 2025
Powered by FUDForum. Page generated in 0.04119 seconds
