Home » Eclipse Projects » Eclipse Platform » Biggest Eclipse bug still exist! PC reinstall + clean install = STILL!
Re: Biggest Eclipse bug still exist! PC reinstall + clean install = STILL! [message #328161 is a reply to message #328156] |
Thu, 15 May 2008 18:38   |
Originally posted by: davisons.qwest.com
Mr. Hama,
I've read the history provided by your first link. First let's make sure
that I understand your complaint. You create a file, type something into
it, and then save it. Then you open the file, delete some content, and save
it again. Your complaint is that the file size on the disk has not changed?
I hesitate to offer any futher advice until I'm absolutely sure your problem
is as I have described it.
Stephen
"Mr. Hama" <hamasaki@citromail.hu> wrote in message
news:eccc36fc1a287a82a0bfaacc7e6d1697$1@www.eclipse.org...
> History:
> http://www.eclipse.org/newsportal/article.php?id=41027&g roup=eclipse.platform.swt#41027
> I download from here:
> http://archive.eclipse.org/webtools/downloads/drops/R1.5/R-1 .5.5-200708291442/
> This:
> wtp-all-in-one-sdk-R-1.5.5-200708291442-win32.zip
> http://www.eclipse.org/downloads/download.php?file=/webtools /downloads/drops/R1.5/R-1.5.5-200708291442/wtp-all-in-one-sd k-R-1.5.5-200708291442-win32.zip
> installing:
> Sun Java 2 Standard Edition 1.4.2_10
> Sun Java 2 Standard Edition, version 1.4.2_08 for Microsoft Windows
> extracting eclipse and run... AND THIS BUG EXTIST:
> If i delete from file, file size will same, don't be smaller!
> Read top link about this bug.
> How can it possible?
> I have new Windows XP install, all works perfectly expect Eclipse.
> Hama
Re: Biggest Eclipse bug still exist! PC reinstall + clean install = STILL! [message #328189 is a reply to message #328164] |
Fri, 16 May 2008 11:43   |
I would reproduce it myself. However you have to be extremely detail.
For example, I don't know how to get a version of WTP. How did delete
it? Did you use menu or delete key.
By the way, have you tried going to control panel -> system, and
turning off the "screw people up" feature off? Hehehe. No, I couldn't
resist the last part as a joke.
-Derek Lac
> The best way to get a bug fixed is to open a bug report and provide
> steps to reproduce.
> Since it seems to be easily reproducable, please mention all what you
> have done to get it.
> Now if you are using old versions of Eclipse and WTP, it could be a good
> idea to try to reproduce first on the latest versions.
> Then I would try to reproduce without WTP to try to isolate the problem.
> Once the bug is entered, it will be the good place to track it down.
> Olivier
Re: Biggest Eclipse bug still exist! PC reinstall + clean install = STILL! [message #328199 is a reply to message #328161] |
Fri, 16 May 2008 15:16   |
If the file size is the same it would be because the file contents fit
into the same number of file system blocks as the original. (e.g: I type
"hello world" into foobar.txt with notepad and save, it is a 1K file
on my machine. I erase 'world' and save and I still have a 1K file)
If the content you can see doesn't change after you delete something and
save and re-open then that's different but I have never had that kind of
problem with any of the Eclipse editors ever.
Steve Blass
Stephen Davison wrote:
> Mr. Hama,
> Stephen
>> History:
>> This:
>> installing:
>> Hama
Re: Biggest Eclipse bug still exist! PC reinstall + clean install = STILL! [message #328263 is a reply to message #328199] |
Tue, 20 May 2008 09:39   |
From the description he gave it certainly read like he didn't understand the
concept of internal fragmentation (aka slack space). I just wanted to make
sure that's what he was really describing.
Stephen
"Steve Blass" <sblass@acm.org> wrote in message
news:g0kmjj$hv5$1@build.eclipse.org...
> "hello world" into foobar.txt with notepad and save, it is a 1K file on my
> machine. I erase 'world' and save and I still have a 1K file) If the
> content you can see doesn't change after you delete something and save and
> re-open then that's different but I have never had that kind of problem
> Steve Blass
>> Mr. Hama,
>> save it again. Your complaint is that the file size on the disk has not
>> changed?
>> problem is as I have described it.
>> Regards,
>> Stephen
>>> History:
>>> This:
>>> installing:
>>> Hama
Re: Biggest Eclipse bug still exist! PC reinstall + clean install = STILL! [message #328332 is a reply to message #328328] |
Wed, 21 May 2008 12:55  |
Mr. Hama wrote:
> If helps, I made the swf / avi video about this bug. Like open file,
> remove lines, reopen file, and the old content exists.
> Why noone can help me?
> Noone can reproduct this bug?
That is correct - no one else has reported anything like this; it is
unique to your environment. As I told you when you first posted, this
kind of bug would have been found and fixed a long time ago if it were
consistent for other users. So clearly it is something unique in your
system.
Where it the video you made? That would probably be very helpful to see...
Eric
Current Time: Fri Jul 18 01:56:07 EDT 2025
Powered by FUDForum. Page generated in 0.41269 seconds
