Home » Eclipse Projects » Eclipse Platform » CVS: reverting to previous revision
| CVS: reverting to previous revision [message #328126] |
Wed, 14 May 2008 15:11  |
Originally posted by: first.last.oracle.com
Is there a way to revert to a previous CVS revision,
so that the file then shows up in the Synchronize view
as an "incoming" change?
I can replace a file with a previous revision,
but then it shows up as an "outgoing" change.
Thanks.
Brian
| Re: CVS: reverting to previous revision [message #328159 is a reply to message #328148] |
Thu, 15 May 2008 18:19   |
Well, I played around a bit: If you edit the appropriate ./CVS/Entries file
and change the file's revision number to the desired number and then restart
Eclipse, "synchronizing" will give me the behavior I am looking for.
For example, change
/Foo.java/1.3/Wed May 14 20:22:24 2008//
to
/Foo.java/1.2/Wed May 14 20:22:24 2008//
and things seem OK. Of course, there might be some side-effect I'm not aware
of just yet....
Just for the record.
Brian Vosburgh wrote:
> Bullseye! :-) *Someone* understands me! (Unfortunately it's Wayne. :-) )
> I guess I thought that, since Eclipse can tell which revision I checked
> out originally (I think the revision number is in the ./CVS/Entries file),
> Eclipse could simply alter that setting and now think that I had checked
> out another revision (1.2, in the example below). Oh well....
> Thanks.
> Brian
> Wayne Beaton wrote:
>> What do you think CVS is? Envy?
>> Wayne
>> On Thu, 2008-05-15 at 00:58 -0400, Brian Vosburgh wrote:
>>> Maybe my description wasn't very clear.
>>> I have file Foo.java. It has several revisions on the CVS repository
>>> (1.1, 1.2, 1.3). When I "synchronize" my workspace with the repository,
>>> Eclipse indicates that my workspace is in synch with HEAD (i.e. the
>>> Foo.java revision in my workspace is 1.3). I would like to "check out"
>>> revision 1.2 and have subsequent "synchronizations" with the repository
>>> to tell me that there is an "incoming" change available for Foo.java
>>> (that
>>> incoming change being revision 1.3).
>>> I can see how I get the contents of Foo.java revision 1.2: Team ->
>>> Show History -> Get Contents. But then "synchronize" indicates I have
>>> an "outgoing" change. I would like my client (i.e. Eclipse) to know
>>> the current revision in my workspace is 1.2 and that "synchronize"
>>> should tell me I now have an "incoming" change.
>>> Is there any way to do that?
>>> Thanks.
>>> Brian
| Re: CVS: reverting to previous revision [message #328180 is a reply to message #328159] |
Fri, 16 May 2008 10:01   |
> restart
> For example, change
> to
> aware
> of just yet....
I suggest you ask on a CVS support forum about the validity and safety
of doing that. If there is no reason not to, I'd suggest entering a
feature request against Eclipse's CVS component to implement something
like that in the UI.
Eric
>> file),
>> Thanks.
>> Brian
>>> Wayne
>>>> (that
>>>> Thanks.
>>>> Brian
| Re: CVS: reverting to previous revision [message #328264 is a reply to message #328180] |
Tue, 20 May 2008 09:45   |
Brian,
By all means, enter a bug report. In the past, I used a utility plug-in
I wrote that provided this type of support for CVS (i.e. the action was
called Move to HEAD and would remove any tags from the local file copy
area). I don't think we would ever add this action to the CVS feature
but we could definitely make it available in the repository.
Michael
>> file
>> restart
>> For example, change
>> to
>> aware
>> of just yet....
> Eric
>>> file),
>>> Thanks.
>>> Brian
>>>> Wayne
>>>>> repository,
>>>>> repository
>>>>> Foo.java (that
>>>>> Thanks.
>>>>> Brian
| Re: CVS: reverting to previous revision [message #332490 is a reply to message #328135] |
Wed, 22 October 2008 16:38  |
Originally posted by: javidjamae+javalobby.gmail.com
I tried doing a "Team -> Revert to Base" and it does *not* replace with HEAD.
I tried Revert to Base with version 1.34 on a file that was version 1.36 on the server. I modified the file locally then ran Revert to Base and it replaced the contents with the 1.34 version and took off the dirty flag (the ">" character) that says I'm out of sync with CVS.
So, revert to base did what what the original poster wanted to do and replaced the modified file with the version that he originally checked out.
To replace with head you have to use "Replace -> Replace with Head".
Current Time: Tue Nov 18 21:05:52 EST 2025
Powered by FUDForum. Page generated in 0.07332 seconds
