Hanging System level Job - need help debugging [message #328111] |
Wed, 14 May 2008 07:54  |
I have a problem where a background job is reported to be running in the
lower right corner - but there is no indication of what this job is or
what it is doing in the Progress View. So it is probably a system level
job of some kind.
Greatful for debugging tips how can I find out which job this is, and
what it is doing.
- henrik
Re: Hanging System level Job - need help debugging [message #328116 is a reply to message #328111] |
Wed, 14 May 2008 09:46  |
--------------030309060507020405020502
Henrik,
If you are running under debug control and you stop the process, you
can check what each thread is doing. The instructions in here might
help too because they describe how you can get a stack traces from your
running process:
http://wiki.eclipse.org/index.php/How_to_report_a_deadlock
Henrik Lindberg wrote:
> the lower right corner - but there is no indication of what this job
> is or what it is doing in the Progress View. So it is probably a
> system level job of some kind.
> what it is doing.
> Regards
> - henrik
<html>
<head>
<title></title>
</head>
Henrik,<br>
<br>
running process:<br>
<blockquote><a
href="http://wiki.eclipse.org/index.php/How_to_report_a_deadlock">http://wiki.eclipse.org/index.php/How_to_report_a_deadlock</a><br>
</blockquote>
<br>
<blockquote cite="mid:g0ejt7$9ij$1@build.eclipse.org" type="cite">Hi,
<br>
the lower right corner - but there is no indication of what this job is
or what it is doing in the Progress View. So it is probably a system
<br>
<br>
what it is doing.
<br>
<br>
<br>
- henrik
<br>
</blockquote>
<br>
</body>
</html>
--------------030309060507020405020502--
FUDForum. Page generated in 0.04076 seconds
