Home » Eclipse Projects » Eclipse Platform » Import team project set outside the workspace
Import team project set outside the workspace [message #328081] Tue, 13 May 2008 15:18 Go to next message
Originally posted by: will.houck.gmail.com
It seems that team project sets (.psf files) always import the project
list to the same directory as the workspace. Is it possible specify an
alternate location as you can with new projects, imported projects and the
checkout wizard?
I tried manually modifying the psf file to ref an alternate location but
as expected, this did not work.
Will
Re: Import team project set outside the workspace [message #328091 is a reply to message #328081] Tue, 13 May 2008 16:20 Go to previous messageGo to next message
--------------090402000006020400080106
Will,
No, it's a very annoying limitation:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163439
> an alternate location as you can with new projects, imported projects
> and the checkout wizard?
> but as expected, this did not work.
> Will
<html>
<head>
http-equiv="Content-Type">
</head>
Will,<br>
<br>
No, it's a very annoying limitation:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=163439">https://bugs.eclipse.org/bugs/show_bug.cgi?id=163439</a><br>
</blockquote>
<br>
Will wrote:
<blockquote
cite="mid:0ff314ae962fd0e4800bc2226c75c333$1@www.eclipse.org"
type="cite">It seems that team project sets (.psf files) always import
the project list to the same directory as the workspace.
Re: Import team project set outside the workspace [message #328095 is a reply to message #328091] Tue, 13 May 2008 19:34 Go to previous messageGo to next message
Ed, thanks for the info. Any suggested work arounds? I've experimented
with ant tasks leveraging projectImport which solves the issue of
alternate project locations, but then I still have to manually enable cvs
for each project via menu option Team/Projecct Share.
Re: Import team project set outside the workspace [message #328097 is a reply to message #328095] Tue, 13 May 2008 19:45 Go to previous messageGo to next message
Will,
I've not figured out a workaround. :-(
> experimented with ant tasks leveraging projectImport which solves the
> issue of alternate project locations, but then I still have to
> manually enable cvs for each project via menu option Team/Projecct Share.
Re: Import team project set outside the workspace [message #328118 is a reply to message #328097] Wed, 14 May 2008 10:12 Go to previous messageGo to next message
Ed and Will,
The best workaround is to provide a patch that adds a prompt for an
alternate parent folder as described in the bug report ;-)
Michael
Ed Merks wrote:
> Will,
Re: Import team project set outside the workspace [message #328120 is a reply to message #328118] Wed, 14 May 2008 10:16 Go to previous message
Michael,
But I'm so busy and you have copious spare time. :-P
I helped provide a few patches to PDE last week, so maybe I'll take a
kick at the CVS can one of these days too. Be careful what you ask for!
Michael Valenta wrote:
> Ed and Will,
> Michael
> Ed Merks wrote:
>> Will,
>>> the issue of alternate project locations, but then I still have to
>>> Share.
Previous Topic:Hanging System level Job - need help debugging
Next Topic:how to prevent statusbar resize
Current Time: Sun Aug 31 09:14:35 EDT 2025
Powered by FUDForum. Page generated in 0.24251 seconds
