Home » Eclipse Projects » Eclipse Platform » Launch an external program
Launch an external program [message #328067] Tue, 13 May 2008 10:18 Go to next message
Originally posted by: messineo.rosario.gmail.com
I'm configuring an development environment for one embedded language on
Eclipse and I want invoke an external program that already implements some
feature. I'm able to launch it configuring properly a new configuration
from External Tools but I want that user of environment doesn't spend time
to set this configuration manually. My idea would be creating a new plugin
and add to it both the program (written in C#) and something that enables
the launch configuration such as that produced using External Tools menu
manually.
Which could be the best solution to implement my idea?
How can I add launch configuration details to eclipse platform?
Thanks in advance
Rosario
Re: Launch an external program [message #328101 is a reply to message #328067] Tue, 13 May 2008 23:24 Go to previous message
Originally posted by: ronbermejo.nospamm.com
Rosario wrote:
> manually.
> Thanks in advance
> Rosario
Hi Rosario,
The easiest way would be to export the launch configuration as a file. In
the 'Common' tab of the External Tools Dialog, you can choose 'Save
As'->'Shared file' and it will save the configuration as a .launch file.
This file can then be shared with your users.
Hth,
Ron
Previous Topic:project.getWorkingLocation()
Next Topic:[DataBinding]Problem on ValidateStatus Change Listener
Current Time: Sat Jul 26 09:27:58 EDT 2025
Powered by FUDForum. Page generated in 0.09829 seconds
