Home » Eclipse Projects » Eclipse Platform » jface databinding snippet 13
jface databinding snippet 13 [message #328059] Tue, 13 May 2008 09:28 Go to next message
Originally posted by: lukas.myslivec.com
i am playing around with databinding. everything works greate and i like
it very much.
but i have tryed to compile snippet13 but i fails because
ObservableValueEditingSupport could no resolved.
i have tryed to googeld ObservableValueEditingSupport but no results
returend.
regards
lukas
Re: jface databinding snippet 13 [message #328061 is a reply to message #328059] Tue, 13 May 2008 09:37 Go to previous messageGo to next message
You need 3.4M6 to make this work.
Tom
lukas schrieb:
> Hello,
> it very much.
> returend.
> regards
> lukas
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: jface databinding snippet 13 [message #328105 is a reply to message #328061] Wed, 14 May 2008 03:56 Go to previous messageGo to next message
Hi tom,
thank you for this important information.
maybe you could update the code because the code comment says "reuqires
3.3"
regards
lukas
Re: jface databinding snippet 13 [message #328107 is a reply to message #328105] Wed, 14 May 2008 04:06 Go to previous message
I think the original one required 3.3 but has been changed when the new
built in support was available.
I'm not a committer on eclipse-databinding please file a bug and the
guys responsible will fix it.
Tom
lukas schrieb:
> Hi tom,
> 3.3"
> regards
> lukas
Previous Topic:[DataBinding]Problem on ValidateStatus Change Listener
Next Topic:Hanging System level Job - need help debugging
Current Time: Fri Jul 18 08:19:03 EDT 2025
Powered by FUDForum. Page generated in 0.03446 seconds
