Home » Eclipse Projects » Eclipse Platform » Strange Behavior when adding a FormPage into SharedHeaderFormEditor
Strange Behavior when adding a FormPage into SharedHeaderFormEditor [message #328055] Tue, 13 May 2008 08:39 Go to next message
Im using a SharedHeaderFormEditor and want to add a FormPage into the
editors 'body'
In SharedHeaderFormEditor addPages function I'm doing the following:
protected void addPages() {
try {
myFormPage = new MyFormPage(this, MyFormPage.ID, "MyFormPage");
addPage(0, myFormPage);
} catch (PartInitException e) {
e.printStackTrace();
As result I'm getting an exception refer to FormEditor line 490:
at org.eclipse.ui.forms.editor.FormEditor.pageChange(FormEditor .java:490)
org.eclipse.ui.forms.editor.FormEditor.setActivePage(FormEdi tor.java:623)
When debugging into this I find the following line:
fpage.getPartControl().setMenu(getContainer().getMenu());
In my case getContainer().getMenu() returns null. (why ever...). This
seems to cause the exception.
Is this a bug, or is there something obviously wrong with my code?
Jan
Re: Strange Behavior when adding a FormPage into SharedHeaderFormEditor [message #328057 is a reply to message #328055] Tue, 13 May 2008 08:59 Go to previous message
I solved the problem myself.
I'd tried araound for hours before posting this email. Just a minute after
this I thought to try one last thing.
My mistake was to create the forms content in createPartControl() and not
in createFormContent().
Previous Topic:Troubleshooting OSGi
Next Topic:How To Access Folders When Testing Plugins
Current Time: Thu Jul 24 03:42:56 EDT 2025
Powered by FUDForum. Page generated in 0.27854 seconds
