Home » Eclipse Projects » Eclipse Platform » Suggestion: Syntax Coloring Eclipse 3.4
Suggestion: Syntax Coloring Eclipse 3.4 [message #328022] Mon, 12 May 2008 13:46 Go to next message
The new 3.4 java syntax coloring is so bad that at first i could hardly
understand the code. Things ought to look better as in previous versions.
I suggest for comments (0,128,0), for keywords (0,0,255) as in String as
well.
I think the rest is fine, but those changes are really needed.
Re: Suggestion: Syntax Coloring Eclipse 3.4 [message #328024 is a reply to message #328022] Mon, 12 May 2008 13:59 Go to previous messageGo to next message
Open a bug report and report the id for it.
FWIW, I disagree with you, but you should still open the bug report.
Wayne
> well.
Re: Suggestion: Syntax Coloring Eclipse 3.4 [message #328032 is a reply to message #328022] Mon, 12 May 2008 16:21 Go to previous message
> well.
Are you aware that you can change the syntax coloring in the
Preferences? Just type "syntax" (without quotes) in the search box at
the top of the Preferences dialog, and you'll find the settings to change.
Eric
Previous Topic:[JFace] ViewerColumn and EditingSupport
Next Topic:Using F3 key with and without JDT
Current Time: Sat May 10 21:43:42 EDT 2025
Powered by FUDForum. Page generated in 0.03484 seconds
