Home » Eclipse Projects » Technology Project and PMC » local variables unavailable
local variables unavailable [message #33206] Wed, 06 November 2002 16:18 Go to next message
Originally posted by: ksingh.bea.com
When using eclipse to step into my program, I am not able to display the
variable or inspect it as it is not getting resolved.
It says
<Variable Name>
Evaluation failed. Reason(s)
<variable name> cannot be resolved.
How I use eclipse:
I run my java program and then attach to this program using eclipse
Thanks in advance.
-sunny
Re: local variables unavailable [message #33252 is a reply to message #33206] Wed, 06 November 2002 18:56 Go to previous message
Originally posted by: alexander.jesse.falconjsoft.ch
are you using Ant to compile?
If yes: in Ant 1.4.1 there is a bug that makes the generation of debugging
information impossible... A bug should have been opened a few days ago...
hth
Alexander
> It says
> <Variable Name>
> How I use eclipse:
> Thanks in advance.
> -sunny
Re: local variables unavailable [message #33322 is a reply to message #33252] Wed, 06 November 2002 16:43 Go to previous message
That was it. Thanks.
-sunny
Alexander Jesse wrote:
> hth
> Alexander
> > It says
> > <Variable Name>
> > How I use eclipse:
> > Thanks in advance.
> > -sunny
Re: local variables unavailable [message #585546 is a reply to message #33206] Wed, 06 November 2002 18:56 Go to previous message
hth
Alexander
> It says
> <Variable Name>
> How I use eclipse:
> Thanks in advance.
> -sunny
Re: local variables unavailable [message #585572 is a reply to message #33252] Wed, 06 November 2002 16:43 Go to previous message
-sunny
> hth
> Alexander
> > It says
> > <Variable Name>
> > How I use eclipse:
> > Thanks in advance.
> > -sunny
Previous Topic:Adding jars in a plug-in classpath
Next Topic:Java Software Protection & Licensing Methods..
Current Time: Sat Jul 19 00:00:45 EDT 2025
Powered by FUDForum. Page generated in 0.04291 seconds
