Home » Eclipse Projects » Eclipse Platform » [DataBinding] Tracking dirty model on DataBindingContext
[DataBinding] Tracking dirty model on DataBindingContext [message #327988] Mon, 12 May 2008 05:04 Go to next message
Originally posted by: malloovidio.bluewin.ch
Hi all,
I'm implementing an editor for which I'm using databinding. In the
actual editor, I'm creating a DataBindingContext which I then pass to
several classes which create portions of the editor's UI, along with
the corresponding bindings to the model.
In the editor, I wanted to track the dirty state of the model where
my first thought was to simply attach value change listeners to all
model observables of all the bindings of the DataBindingContext.
However, in my editor, I'm using several master/detail constructs
which means that some of my model observables are DetailObservableValues
whose value not only changes when the model indeed changes but also
when a different master is selected.
Therefore, my approach described above seems inappropriate as I should
not be listening on changes on the DetailObservableValues but on the
model observables they contain.
Since tracking the dirty state of a model being edited should be a
fairly standard thing, I was just wondering whether anyone else has
implemented something similar using databinding which solves the
above problem.
Thanks in advance for any feedback!
Ovidio
Re: [DataBinding] Tracking dirty model on DataBindingContext [message #327990 is a reply to message #327988] Mon, 12 May 2008 05:26 Go to previous messageGo to next message
Well IMHO the best way is to record all changes happening to the model.
Databinding doesn't provide such a thing, having said that the only
thing that always comes to my my mind is EMF which provides a class
called ChangeRecorder and attaching it to your master model object(s)
would record all changes happening below :-) This provides another cool
thing to you because you can rollback changes. If you would use an
EditingDomain you'll even get undo/redo, great isn't it?
Tom
Ovidio Mallo schrieb:
> Hi all,
> above problem.
> Best regards,
> Ovidio
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [DataBinding] Tracking dirty model on DataBindingContext [message #327992 is a reply to message #327990] Mon, 12 May 2008 06:28 Go to previous messageGo to next message
Hi Tom,
first of all, thanks a lot for the immediate response and the good
hints!
Indeed, EMF seems to have some great features which work out of the box.
Unfortunately, the editor I'm implementing is part of a large project
which can hardly be adapted with hindsight to use EMF.
However, based on your hint about the EditingDomain below, I had just a
look at the EditingDomainEObjectObservableValue class of EMF which seems
to nicely integrate the dirty/undo/redo features into the databinding
world. Seems as if this could be a promising solution to our problem,
especially due to the undo/redo support which we might want to have in
a future version of our editor, too.
Thanks again for your help!
Ovidio
> Tom
>> Hi all,
>> above problem.
>> Best regards,
>> Ovidio
Re: [DataBinding] Tracking dirty model on DataBindingContext [message #327994 is a reply to message #327992] Mon, 12 May 2008 06:31 Go to previous messageGo to next message
Yes that's what I talked about. I'm still not sure why you can't use
ChangeRecorder it looks as if you are using EMF (just saw a posting on
the EMF-newsgroup from you) but using an EditingDomain is even better.
Tom
> Hi Tom,
> hints!
> Best regards,
> Ovidio
>> cool thing to you because you can rollback changes. If you would use
>> an EditingDomain you'll even get undo/redo, great isn't it?
>> Tom
>>> Hi all,
>>> above problem.
>>> Best regards,
>>> Ovidio
Re: [DataBinding] Tracking dirty model on DataBindingContext [message #327998 is a reply to message #327994] Mon, 12 May 2008 07:39 Go to previous messageGo to next message
Hi again Tom,
actually, I have only started looking at EMF about two weeks ago, but
I'm very interested in it, especially in the databinding support
provided by EMF (hence the post on the EMF newsgroup).
However, right now, I'm merely using EMF for some toy project of mine,
just to get started and to learn how EMF works.
However, we are not using EMF for the project I was mentioning, so
I cannot use the ChangeRecorder. Of course, I can also not use the
EditingDomainEObjectObservableValue class as is but I think that the
conceptual idea behind that class could fit our purposes, so I will
probably try to go into that direction.
Kind regards,
Ovidio
Tom Schindl wrote:
> Tom
>> Hi Tom,
>> hints!
>> a look at the EditingDomainEObjectObservableValue class of EMF which
>> seems
>> Best regards,
>> Ovidio
>>> Tom
>>>> Hi all,
>>>> above problem.
>>>> Best regards,
>>>> Ovidio
Re: [DataBinding] Tracking dirty model on DataBindingContext [message #328114 is a reply to message #327998] Wed, 14 May 2008 08:20 Go to previous messageGo to next message
Originally posted by: tom.eiswind.de
Hi Ovidio,
I track changes with a global helper on the binding level.
public static void addDirtyListenersToContext(DataBindingContext
context, DirtyListener dirtyListener){
DirtyChangeListener listener = new DirtyChangeListener(dirtyListener);
IObservableList bindings = context.getBindings();
for (Object o : bindings) {
Binding b = (Binding) o;
b.getTarget().addChangeListener(listener);
If your bindings change you could listen to the bindings list and react.
Thomas
> Hi again Tom,
> Kind regards,
> Ovidio
> Tom Schindl wrote:
>> Tom
>>> Hi Tom,
>>> hints!
>>> seems
>>> Best regards,
>>> Ovidio
>>>> object(s) would record all changes happening below :-) This provides
>>>> another cool thing to you because you can rollback changes. If you
>>>> would use an EditingDomain you'll even get undo/redo, great isn't it?
>>>> Tom
>>>>> Hi all,
>>>>> above problem.
>>>>> Best regards,
>>>>> Ovidio
Re: [DataBinding] Tracking dirty model on DataBindingContext [message #328122 is a reply to message #327988] Wed, 14 May 2008 11:24 Go to previous messageGo to next message
Ovidio,
DetailObservableValue (and its List, Set and Map variants) works by
watching the master observable and replacing the detail observable each
time the master changes. That is, it disposes the old detail
observable, and requests a new detail observable from the
IObservableFactory passed to its constructor.
Thus, many of the observeDetailValue methods in BeansObservables,
PojoObservables, EMFObservables, etc are really just a convenient
shorthand for creating an observable factory, and passing it to
MasterDetailObservables.detailValue(). e.g.:
IObservableValue detailObservableValue = BeansObservables
.observeDetailValue(realm, masterObservable, "property",
propertyType);
is pretty much the same as:
IObservableFactory valueFactory = BeansObservables
.valueFactory(realm, "property");
IObservableValue detailObservableValue = MasterDetailObservables
.detailValue(masterObservable, valueFactory, propertyType);
You could observe changes to the detail observable while ignoring
changes to the master observable by wrapping valueFactory in a custom
factory:
class MyObservableFactory implements IObservableFactory {
IObservableFactory factory;
public MyObservableValueFactory(IObservableFactory factory) {
this.factory = factory;
public IObservable createObservable(final Object target) {
IObservable result = factory.createObservable(target);
result.addChangeListener(new IChangeListener() {
public void handleChange(ChangeEvent event) {
// Change occured in model -- mark editor as dirty
return result;
valueFactory = new MyObservableFactory(valueFactory);
Does this help?
Matthew
Ovidio Mallo wrote:
> Hi all,
> above problem.
> Best regards,
> Ovidio
Re: [DataBinding] Tracking dirty model on DataBindingContext [message #328167 is a reply to message #328114] Fri, 16 May 2008 03:08 Go to previous messageGo to next message
Hi Thomas,
I think that the approach of simply listening to all target observables
of a DataBindingContext still has the problem that if you have
master/detail constructs in the GUI, the target observables will typically
change whenever you change your master even though your model has not
really changed. So, in those cases I think it is not OK to listen to the
target/model observables of the DataBindingContext as you would erroneously
mark your editor as being dirty even though nothing changed.
Ovidio
Thomas wrote:
> Hi Ovidio,
> Thomas
>> Hi again Tom,
>> Kind regards,
>> Ovidio
>> Tom Schindl wrote:
>>> Hi,
>>> on the EMF-newsgroup from you) but using an EditingDomain is even
>>> better.
>>> Tom
>>>> Hi Tom,
>>>> hints!
>>>> box.
>>>> just a look at the EditingDomainEObjectObservableValue class of EMF
>>>> which seems
>>>> Best regards,
>>>> Ovidio
>>>>> model.
>>>>> provides another cool thing to you because you can rollback
>>>>> changes. If you would use an EditingDomain you'll even get
>>>>> Tom
>>>>>> Hi all,
>>>>>> should
>>>>>> above problem.
>>>>>> Best regards,
>>>>>> Ovidio
Re: [DataBinding] Tracking dirty model on DataBindingContext [message #328169 is a reply to message #328122] Fri, 16 May 2008 03:45 Go to previous message
Hi Matthew,
I think your idea is great. I have just implemented it for my
editor and it works like a charm :-).
Thanks a lot for your help and the clear explanation.
Ovidio
Matthew Hall wrote:
> Ovidio,
> propertyType);
> factory:
> return result;
> Does this help?
> Matthew
> Ovidio Mallo wrote:
>> Hi all,
>> above problem.
>> Best regards,
>> Ovidio
Previous Topic:Status of the Remote help Proposal
Next Topic:Minimize/Maximize buttons on title bar not working
Current Time: Thu Jul 17 22:18:54 EDT 2025
Powered by FUDForum. Page generated in 0.11873 seconds
