Home » Eclipse Projects » Eclipse Platform » execute Command from a Property Page
execute Command from a Property Page [message #327925] Thu, 08 May 2008 10:15 Go to next message
from a PropertyPage, i'm trying to execute a Command that opens another
Window/Dialog:
What i get is the following Exception:
org.eclipse.core.commands.ExecutionException: No activeWorkbenchWindow
found while executing org.eclipse.ui.help.aboutAction
What is wrong?
Help is greatly appreciated.
Simon
Detailed Code:
public class APropertyPage extends PropertyPage {
protected Control createContents(Composite parent) {
Composite composite = new Composite(parent, SWT.NONE);
composite.setLayout(new GridLayout(2, true));
Link link = new Link(composite, SWT.LEFT);
link.setText("<a>Command...</a>");
link.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event event) {
final IHandlerService handlerService = (IHandlerService) PlatformUI
.getWorkbench().getService(IHandlerService.class);
try {
handlerService
.executeCommand(
"org.eclipse.ui.help.aboutAction",
event);
catch (Exception e) {
e.printStackTrace();
return composite;
Stack Trace:
at org.eclipse.ui.handlers.HandlerUtil.noVariableFound(HandlerU til.java:38)
org.eclipse.ui.handlers.HandlerUtil.getVariableChecked(Handl erUtil.java:86)
org.eclipse.ui.handlers.HandlerUtil.getActiveWorkbenchWindow Checked(HandlerUtil.java:188)
at org.eclipse.ui.internal.about.AboutHandler.execute(AboutHand ler.java:34)
org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:240)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:475)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:174)
at APropertyPage$1.handleEvent(ZuglaufPropertyPage.java:73)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Link.wmNotifyChild(Link.java:932)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4563)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:15 81)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4216)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3724 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4364 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:217 9)
at org.eclipse.swt.widgets.Link.callWindowProc(Link.java:124)
at org.eclipse.swt.widgets.Widget.wmLButtonUp(Widget.java:1817)
at org.eclipse.swt.widgets.Control.WM_LBUTTONUP(Control.java:40 12)
at org.eclipse.swt.widgets.Link.WM_LBUTTONUP(Link.java:784)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3706 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDial ogAction.java:156)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
ch.sbb.rcsd.client.application.internal.RCSDApplication.star t(RCSDApplication.java:36)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Re: execute Command from a Property Page [message #328656 is a reply to message #327925] Fri, 30 May 2008 11:06 Go to previous message
> Window/Dialog:
> What is wrong?
Apparently that command won't run from a dialog. It needs the active
workbench window, and it looks like a dialog window means there's no
active workbench window in the global application context.
What version of eclipse? There were some changes that went into that
code in 3.4 (RC2 is out, we're almost at RC3)
> Stack Trace:
> at
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:[Accessibility] Decorations in views not read by Windows Eyes
Next Topic:Determining when the project was refreshed the last time
Current Time: Tue Jul 22 11:11:28 EDT 2025
Powered by FUDForum. Page generated in 0.05713 seconds
