Home » Eclipse Projects » Eclipse Platform » how to write a runner
how to write a runner [message #327906] Thu, 08 May 2008 01:23 Go to next message
hi all,
I I made a new perspective now I would like to use the run dialog to
create a runner
it's a external runner (in fact it's just a make with lots of parameter)
with extention point I have to load to have in the 'open run dialog) a
new tab with my language, etc...ec...
and if you have some web site it's would be very cool
thanks
a+++
Re: how to write a runner [message #327907 is a reply to message #327906] Thu, 08 May 2008 04:38 Go to previous messageGo to next message
Originally posted by: ronbermejo.nospamm.com
julien wrote:
> hi all,
> create a runner
> thanks
> a+++
If you want to just run make you don't need a new plug-in you can just use
CDT (Makefile project) or even the 'External Tools' (Program) in the run
dialog.
But if you want to add your own tabbed folders, etc you have to extend the
debug/launch framework. A good starting point would be:
http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.isv/guide/debug.htm
Are you using make as a build tool? (Build and launch/debug are 2
different things) If so, Eclipse CDT already has extensive support for
make build so maybe it would be better to just start from there.
Hope this helps,
Ron
Re: how to write a runner [message #327913 is a reply to message #327907] Thu, 08 May 2008 07:03 Go to previous messageGo to next message
Ron Bermejo a écrit :
> julien wrote:
>> hi all,
>> create a runner
>> thanks
>> a+++
> use CDT (Makefile project) or even the 'External Tools' (Program) in the
> run dialog.
> the debug/launch framework. A good starting point would be:
> Hope this helps,
> Ron
thanks, yep this helps
a++
Re: how to write a runner [message #327915 is a reply to message #327907] Thu, 08 May 2008 07:22 Go to previous message
hue, in fact that involve other question
to be simple, in a project directory, I have 5 choices
I can do
make
make make
make force
make debug
make forcedebug
What I want is in the toolbar ,I have 5 icons representing this actions
In a first time I thougth the best was 5 actions set and redirect the
output in the consol (after formating )
but After I ve just read , is it possible to use actions set (and so
have the button ) and from that , delegate the action to the laucher??
2 points, I make a plugin for a new language (with editor and so...) and
we don't wanna use the CDT or even the JDT cause we would like more
idependent as possible (long story).
thanks
a++
> julien wrote:
>> hi all,
>> create a runner
>> thanks
>> a+++
> run dialog.
> Hope this helps,
> Ron
Previous Topic:Setting size of window created by PlatformUI.getWorkbench().openWorkbenchWindow
Next Topic:SAXON in Eclipse
Current Time: Fri Jul 18 11:43:53 EDT 2025
Powered by FUDForum. Page generated in 0.04792 seconds
